Go Back   Automotive Forums Car Chat > BMW > Z4 | Z4 Coupe
Old 01-01-2003, 01:04 PM
Menu dei Motori's Avatar
Menu dei Motori Menu dei Motori is offline
Click here
Send a message via ICQ to Menu dei Motori Send a message via AIM to Menu dei Motori Send a message via MSN to Menu dei Motori
z4 sound system
somebody already has experience with the Carver 10-Speaker Premium Audio System
what about the carver technology?
can sb. recommend it?
Old 01-21-2003, 06:11 PM
lowridder11 lowridder11 is offline
Send a message via AIM to lowridder11
It's not Harman Kardon anymore?
Old 01-22-2003, 07:28 AM
Click here
i donīt think so!
Old 01-22-2003, 02:53 PM
that sux
Old 01-24-2003, 04:40 PM
damills damills is offline
Upgraded audio
Ive seen one brouchure that said it was a HK, but one brochure also said floormats are standard, tilt down mirror. To answer your question, the upgraded carver is much better than the HK upgrade in a 3-series (ive had 5). Subs behind seats, directional mounted tweeters at the side mirror level
Ive upgraded the stereo in almost all my cars before (spending $2k-$3k), I wont be doing anything to the Z4, very good IMO
Old 01-24-2003, 04:57 PM
maybe it still is then, but with a CD playa
Old 02-27-2003, 02:16 PM
rosenbimmer rosenbimmer is offline
I wondered the same thing. I was under the impression the upgraded sound system was a HK, but my sales guy told me it's either an Alpine (most likely) or Blaunkpunket (or whatever it's called). The Carver Technology is simply the ability to have it autoadjust the volume with engine noise. It's a pretty good system, but I would've preferred HK, unless someone can convince me that the Alpine is better by showing specs.
Old 06-24-2003, 12:44 PM
Z4newbie Z4newbie is offline
sound system
check the BMW website, but I own a Z4 3.0 with the upograded sound system, the CD changer and the navigation system (thank god the whole country is now on one DVD instead of 6 CDs), and i believe the premium sound system is Harmon Kardon WITH Carver technology for auto adjusting the volume. It works great and my teenage daughter has recently certified, using her music, that I have sufficient bass. That means fillings actually fall out when the right note is played.
Old 06-24-2003, 05:30 PM
Well, I hope you're right about it being a HK. I like to have a lot of bass, but I'm worried about blowing my speakers when I'm driving at fast speeds (because the volume adjusts). So, I turn down the bass by 2 notches to play it safe, but I'm wondering if it is ok to put the bass all the way up. Do you know if this is dangerous to the system?
Old 11-24-2003, 10:25 PM
drachiele drachiele is offline
Z4 sound system
I have had my Z4 in to Fields BMW in Winter Park 6 times for attempts to get the premium sound system to work properly. I keep loosing the bass. When I first got the car, the bass was very loud. Now it is very weak. Anyone have this problem?
Old 12-06-2003, 09:02 PM
drtsiouris drtsiouris is offline
Thumbs up z4 carver sound system
carver is a high end stereo manufacturer that is significantly better than any HK system, and a welcome upgrade. the amplifier in the z4 is carver, and it performs beautifully. it makes the HK system sound like a transistor radio. the two subwoofers and the additional 8 speakers in the small z4 cabin don't hurt much either.
Old 12-09-2003, 03:05 PM
claygraffix claygraffix is offline
2 10" subs in the trunk
Hi guys, I got 2 10" Alpine Type-R's in my trunk a couple months ago. The guys had to drill a porthole through the compartment near the armrest, the one that folds down. So, whenever you want real bass, you have to lower this, but its no big deal. Its worth it, it sounds really good. I went to aout 5 shops in Los Angeles, and 4 of them said it couldn't be done, but one offered this suggestion. Worked for me!
I've still got room to lay a set of golf clubs comfortably in the back.
Clayton
Old 05-12-2007, 02:07 PM
robertrichhart robertrichhart is offline
Re: Z4 sound system
Does anybody know where to find a copy of the BMW audio system manual (hopefully PDF) for the system with Carver technology that is in the Z4 3.0 ?
Sound System for '94 ES300 Balzak ES300/ES330/Windom 3 05-14-2003 03:01 PM
sound system twinz Car Audio 3 01-24-2002 05:08 PM
sound system 94civic Car Audio 27 01-02-2002 04:24 PM
Sound System Fuse!!!!! amer Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 1 12-09-2001 09:44 AM
Sound System on P11 Koojo Audio/Security 9 06-01-2001 05:08 AM
