Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 12-30-2002, 10:46 AM
mad max 98 mad max 98 is offline
Arrow home made nitro kit
hay dudes, did anybody ever tried to make a cheap nitro kit i saw that web site for aguy called john williamson and he explains how to make it check it out and let me know ur opinion and f u pls send some pictures of ur engine with the nitro kit on it :smoker2: thaanks
Old 01-02-2003, 01:36 PM
MaximusGTR's Avatar
MaximusGTR MaximusGTR is offline
Sounds Fishy To Me
Old 01-02-2003, 04:41 PM
MaxPayne MaxPayne is offline
Send a message via AIM to MaxPayne
Seems like this guy is a serious Hobby tuner. I checked out his website located here: http://www.dynopower.freeserve.co.uk/nitrous_oxide/
Any way you cut it, you will still be shelling out some $$ for nitrous. You still need the injection systems and the electronics. This guy besicaly reverse engineered an existing Nitrous system and built himself one based on it.
Old 01-03-2003, 03:11 PM
i'm a serious tuner too i do everything on my max etc. but i never missed with nitro b4 and i figured i have enough common sense not to blow up my babe and in the same time i dont have enough money to buy the very basic kits so i deciced to work my way up with nitro so my ? was where to put the jets
Old 01-05-2003, 08:11 PM
Unhappy
can somebody help me please
Old 01-06-2003, 01:17 PM
Paonessa Paonessa is offline
nitrous is cheezy. at the tracks around here cars with nitrous get booed when they run.
Old 01-17-2003, 04:30 PM
hey
Old 01-17-2003, 04:35 PM
97wvmax 97wvmax is offline
Send a message via AIM to 97wvmax
i wouldnt do that man, somethin could go wrong. and BOOM, no more max
Old 01-17-2003, 07:53 PM
bk2kmax's Avatar
bk2kmax bk2kmax is offline
Well first off, it's not really nitrous, it's n20 and second the n20 is not a flammable gas regardless of what you say on that dumb @$$ movie the Fast & Furious, so I would say as long as you're not running to high of a shot, you should be fine.
I believe the wet kit is safer and as long as you get jets big enough to handle the charge and you probably should see if you need to change your fuel rails, maybe add bigger injectors.
Make sure that you calibrate or optimize your fuel to air ratio, you don't want to run too lean or too rich. Usually people who damage their engine have done so because they didn't do anything to change the setup, they just added the n20 system and ran it, usually ran too big of a shot and bam>there goes your engine.
I could be wrong though, I read this somewhere, so it's just my .02, please don't shoot the messenger.
By the way, it should read bk2k3Max, not bk2kmax.
Old 01-18-2003, 04:28 PM
first, nitrous oxide and n2o are the same thing second n20 isnt flamable what so everrrrrrrrrrrrrr, n2o is a gas in room temerture and is called laughing gas cuz it stimulates ur diaphragm and make u laugh , when it gets too hot it turns to 2 parts of nitrogen and 1 part oooooxigenn, without fuel its comletely inflamable read the whole thread, the same thing was posted on one of my replies
again the ? was where to place the jets?????????????
Old 01-20-2003, 09:30 PM
ConMasta ConMasta is offline
jets...
I assume youre driving a Maxima, which has a V6 engine. Correct? V6 engines therefore have 2 intake manifolds. For a direct port setup, the N20 or nitrous... (I like saying nitrous cause it sounds cooler =) jets will be placed on each intake runner. So, youll need 6, one for each cylinder basically, drilled onto the intake manifold and jetting toward the cylinders.
I plan on making my own nitrous injection system based on the website, but theres one problem. Getting to the manifold itself is quite a hassle... going through your sparkplugs, injectors etc, and my level of experience so far has been mainly book knowledge. Anyways, Ill let you know how it goes.
Conan
Old 01-20-2003, 09:32 PM
shiet
I think Im wrong about the 2 intake manifolds.... someone correct me
Conan
Old 01-20-2003, 11:21 PM
we only have one manifold that has 6 runners, i have a ? how does the ecu sense that extra o2 for a 60 shot nitro and where exactly do u drill the manifold, btw i heard that with nx kit 70 shots max u dont have to change ur fuel system or timing thats why i asked about the ecu sensing the o2 ,, thanx
Old 01-21-2003, 11:54 AM
bk2kmax's Avatar
Not sure about your first question but I've heard the same thing about not having to make any changes to your fuel system and timing, maybe we should check with the fellaz on the org.
Do a search on the org and they will definitely have someone over there who knows, those guys have done just about everything possible to the Max.
Old 01-22-2003, 04:59 PM
a**holes
ypu know bk2k every time i read any thread i see assholes making fun of people and making a big deal out of any ? u cant post any ? anymore cuz some dumb ass will make fun of u for 2 hours in a long ass reply then he ll say go to search button
