Old 12-27-2002, 06:42 PM
civicex90 civicex90 is offline
bad running
My 90 Civic EX has a 1.6L with multi-port FI. It sounds like it's not firing on all plugs, timing light looks normal. Mechanical timing checks out OK. New plugs were carboned up after only 2-3 miles. Any fuel problems that would cause this? It has 186K on it, original fuel pump. Having the injectors cleaned did not help, also changed the fuel filter. Any ideas?
Thanks
civicex90
Old 12-27-2002, 08:06 PM
RedRacerCivic's Avatar
RedRacerCivic RedRacerCivic is offline
Send a message via AIM to RedRacerCivic
your car is running too rich, running too rich causes the spark plugs to carbon up and will make your car run rough a bit, i would check your fuel pressure. Also check to see how dirty your air filter is, clogged air filters might do that.
-1991 Civic Si (Sold)
-1990 Accord EX(Sold)
-2000 Civic Hatch
-1998 Lexus SC300
Click here to see my Shoe!
Old 12-27-2002, 08:10 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
dirty air filter and check your fuel pressure, also check your ECU and see if it throwing a code..a bad map sensor could cause it and/or a bad O2 ensor could also...
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 01-19-2003, 07:27 PM
bad running
First off, thanks for the suggestions.
The fuel pressure and regulator were fine. I metered the injector resisters, they were fine. I metered the spark plug wires, they read 8K ohms, which is good, no drop outs bending the wires. Pick up coils in the distributor were good, cap and rotor OK. Coil metered OK. As a shot in the dark, I put a new igniter module in it.
Finally took it to a shop, they found that at high voltages my spark plug wires were leaking, so I had very poor spark. They had about 45K on them. Changing the wires fixed the problem, and the clean injectors gave me more power in the lower revs.
Next time I won't rely on just an ohm meter test of the wires.
Old 01-19-2003, 07:48 PM
mdnnccivicrcr mdnnccivicrcr is offline
cool, another EX owner... word of advice though, save up for another engine soon b/c for some reason EX's tend to have major engine probs after 150k I've never heard of another car or any of the Si's having that problem just the 90/91 EX.
90 Civic EX *RIP*
90 CRX DX *RIP*
88 Civic DX Sedan (pushing boost) *RIP*
95 Accord LX Sedan
Old 01-19-2003, 11:30 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
Hey man, I hope you stay around the site and continue to post, cause you sound like you have a lot of knowledge about cars which is what we like to have around here.
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 01-19-2003, 11:47 PM
MyFirst4G's Avatar
MyFirst4G MyFirst4G is offline
Send a message via AIM to MyFirst4G
You dont want him cause of his brain, you want him to stay just so there is another 4door around here, man, ur worse than a whore, all you care about is what he drives lol, j/k bro
88 DX Hatch SOLD!
90 Si Hatch Wreck'd :
Done parting out.. Shell is going to fire dept soon to get roof chopped off for some kind of drill.. wait for the movie!!
96 Saturn SL2:
Daily Driver untill 91DX is running!
91 DX Hatch:
Its gonna be Painted CL Type S Grey w/ WW RS kit from 90 Si and JDM CRX front end conversion... Powered by a Turbo'd GSR Motor..... Loot is on the way!!
Official 4th Gen OG
Hype Race Crew
Old 01-19-2003, 11:53 PM
Melt's Avatar
well, it would be nice to have another 4door around here too.
Oh yea!! Make sure you vote in our poll.
http://www.automotiveforums.com/vbul...ighlight=peeps
AF Bay Area Crew
hard start, bad running rix444 F Series 1 06-12-2007 02:27 AM
help!!!! 86 325 with bad running engine bkobob06 3 Series 4 03-02-2007 12:08 PM
Misfiring and bad running chantelle_m 205 1 12-06-2004 03:39 PM
Bad running 89 22re acurapat Pick-Up 0 12-01-2004 05:15 PM
Having a bad run with '94 323M 1.8L MPI Nazgul 323/Protegé/Familia/Etude/Allegro 0 12-29-2002 12:23 AM
