Old 12-27-2002, 05:48 PM
MarWar80 MarWar80 is offline
Engine Swap
Got a question for you guys> I just bought a dodge stealth SOHC but at the time I didn't know what was what. I ended up getting this one because it already had an exhaust system, 18" rims, and a brand new paint job. The whole entire car is also in emaculate shape. Now, I want to know if it would be possible of adding a turbo to it! Any of you know how to?
Old 01-23-2003, 03:46 PM
Scott 02's Avatar
Scott 02 Scott 02 is offline
Banned
Send a message via AIM to Scott 02 Send a message via Yahoo to Scott 02
I think you can. I will talk to someone about it though. They did make a Stealth with a Turbo i believe.
Old 01-23-2003, 09:40 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Yes they had a twin turbo Stealth with a 3.0L DOHC V6.
You have a different engine and I would reccomend an engine swap from a TT Steath. I mean you can put a turbo on your car, you can put a tubo on any engine, it would just be less of a hassle and less expensive to swap the engine. Also you will get a lot more power from it.
Old 01-23-2003, 09:42 PM
Scott 02's Avatar
Banned
A friend has a stealth with a twin turbo and he has out ran everyone he has raced. Beat a 1998 Z-28 Camaro. not bad.
Old 03-12-2003, 11:38 AM
450HPviper's Avatar
450HPviper 450HPviper is offline
The twin turbo Stealth with a 3.0L DOHC V6 was a badass car. Talk about letting the horses run.
Old 03-14-2004, 01:29 AM
meev182 meev182 is offline
Send a message via AIM to meev182
stealth sohc...
i also didnt know what i was doing when i but my first car, (93 sohc stealth) and now that im a bit older, i know alot more. i was also curious about the swaps and what not for the stealth...so heres what i have to say. the stealth came in a sohc fwd 3.0, dohc fwd 3.0, dohc fwd 3.0 R/T, and a awd 3.0 dohc R/T. the block and lower end of all of these are the same, so it IS possible to swap engine heads...the sohc to the dohc. however, you must replace the wiring harness and computer. so i think if you wanted to turbo it, you might as well bore it out while youre at it, seeing you would end up buying a new computer and what not anyways. also, i here some people have bored there vr4/rts out to 4.1 litres?!
*marv
Old 04-10-2004, 12:09 PM
LoneReaper LoneReaper is offline
3si.org
do a search on
www.3si.org/forum
This is a great place to go to if you are interested 3/s
dakota engine swap jpuckett13 Dakota 0 08-23-2010 07:21 PM
1995 olds achieva engine swap help. handymann3 Achieva 2 01-21-2010 09:26 PM
engine swap Cadillakin'98 S-10 1 10-22-2009 09:33 AM
engine swapping E. Frank Performance 6 08-07-2009 06:37 PM
97 Jimmy engine swap gsnats Problem Diagnosis 5 03-06-2009 09:40 PM
