Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 12-27-2002, 03:35 AM
OrigJunior OrigJunior is offline
Unhappy 95 Maxima - Intermittent Power Lock Problem
Has anyone experienced any problems with their electronic door lock occasionally locking themselves in close position when door are shut or when driving and hitting a pothole? Sometimes when I activate the master lock button to unlock all the door locks, all door locks with exception of driver door unlock then lock itself back to closed(locked) position. Its driving me nuts and the local dealership charges over 100 dollars just to inspect and analyze electronic problems. Car is 95 Maxima with over 105K miles and running strong. Any helpful insight and/or suggestions would be appreciated. Thank you for your time,
Old 12-27-2002, 01:23 PM
MaximusGTR's Avatar
MaximusGTR MaximusGTR is offline
Nevr had that problem bro, but that would miss me the hell off, best thing is to get that fixed
Old 01-01-2004, 09:40 AM
bpace bpace is offline
Re: 95 Maxima - Intermittent Power Lock Problem
I have the same problem with my 92. Have you had any luck?
Old 01-16-2004, 12:03 PM
marknc64 marknc64 is offline
I have a similar issue on a 92 SE. Also, sometimes the electronic locks stop working completely. I haven't attempted to get it repaired.
Old 01-17-2004, 04:23 PM
flyingpiranha flyingpiranha is offline
I have a similar problem with my 93 Maxima electronic locks. They work sometimes and then they don’t others. I went to the Nissan Dealer and they said it was the $145 master switch in the drive door that controls the windows and the locks. THAT WAS NOT IT! I wasted my money.
Does anyone have any answers?
Old 01-31-2004, 08:29 PM
rurounicy rurounicy is offline
Send a message via AIM to rurounicy
I had the same problem, the driver's side just locks itself while making a weird noise, then it stopped working for a while and BAM now it's stuck in the lock position *sigh* No matter how hard I pull or do anything, it just won't move. The dealer says it's probably the actuator but since the door won't open, they can't do anything about it. I don't want to break the door panel like they said, help! (IM me at AOL with my user ID)
Old 12-14-2004, 10:54 AM
sjmyers32 sjmyers32 is offline
Every power window and lock dont work in my car but the drivers, any help
Old 12-14-2004, 11:26 AM
BP2K2Max's Avatar
BP2K2Max BP2K2Max is offline
Send a message via AIM to BP2K2Max
is your "window lock" button down?
BP's Rides;
- 2005 Kawasaki Ninja ZX6R- Mods: ECU Jumper, Akrapovic Slip-on, Power Commander III, 8000K HID's.
- 2K2 Maxima 6 Speed-Mods: Advanced Timing, Cattman Cat-back Exhaust, H&R Springs, Tokico Illumina Struts, Konig Theory 19" Rims.
Old 12-14-2004, 12:52 PM
Re: Re: 95 Maxima - Intermittent Power Lock Problem
Of course not I quit smoking ten years ago ~
I pulled the radio out and every wire behind the radio on the harness is electrical taped but thanks for the thought!
Old 12-15-2004, 04:48 AM
hotmaledotcom hotmaledotcom is offline
my dad 3rd gen GXE has the same problem too, in my case, all 4 doors lock while going over bumps
Old 12-15-2004, 03:26 PM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
Just a guess: The driver side switch pack has the only switch [with door master sw] that when activated does just that. Maybe there is:
a. smtg loose
b. broken pcb or sw, provoked by vibration and/or [c.]
c. oxidated connectors and +12V supply power too low
Test like NASA Houston tells astronauts: bounce it with a fist - to simulate a bump to locate the problem point...
Or just repla$e.
92 maxima power lock problem starret30 Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 3 08-16-2010 03:35 AM
Lock, and power seat problems!!!! Jefferscene Taurus | Taurus Wagon 12 01-20-2010 03:00 PM
Explore power lock problem only locks from back kenevile333 Explorer | Explorer Sport Trac 3 04-10-2008 11:42 PM
Power Windows and Power Locks problem... wayfast Cherokee 4 06-12-2005 04:31 AM
intermittent door lock problem kd3yt Intrepid 3 09-26-2004 01:45 PM
