Old 12-23-2002, 11:46 AM
jem7vwh jem7vwh is offline
Problem starting Civic in damp!?
I have a problem guys. My Civic won't start when it's cool and damp outside. I managed to get it started and took it the autoshop. The guys there couldn't cause it to stall again, so they couldn't figure out what's wrong. They seem pretty sure it's not the plugs or the rotor since it only happens when it's damp and cold. Any way I can figure out what's wrong with my car? Maybe the Fuel Injection System? Thanks
Old 12-23-2002, 11:54 AM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
have you checked for ECU trouble codes? it is possible to have them without the check engine light coming on. to check it pull up the carpet under your glove box (pass. side) you'll see a metal box. ECU info at bottom
any other symptoms you have noticed? anything you've change or replaced recently?
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 12-25-2002, 11:28 AM
Thanks for the reply. I checked the ECU codes. I got code 7 and code 16, Throttle Angle, and Fuel Injector.
Old 12-26-2002, 07:11 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
also try the cap and or plug wires if there kinda old...when its running pray a mist of water on the cap and the wires...if it hesitates...theres the problem...
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 12-26-2002, 10:19 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
I think Gunmens right, get a new Cap and Rotor and make sure that cap is bolted on tight so no water can get in.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 12-27-2002, 11:38 AM
amy@af's Avatar
well, since gunnmen got the first one, i'll get the second
the fuel injector code will most likely dissappear into thin air after the ecu is reset. however, i would check it out...better to be safe than sorry. do you have a Si? i would check the wires on the injector plug. make sure nothing is loose. look around the injector for gas leakage. it's very faint in color so take a good look. if everything seems to be in order, the next thing would be to get them cleaned. the DX is only dual port so that you can only really get cleaned.
i had a lot of troubles with injectors over the last year...not much fun
change that cap & rotor (at least check it) and check out the injectors and you should be good to go
Old 12-27-2002, 12:27 PM
How hard is it to change the cap and rotor myself? I'd like to learn how to do this stuff! Thanks for the help guys and ladies
Old 12-27-2002, 06:12 PM
amy@af's Avatar
in case you forget which wires went where ....
