Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Maintenance
Maintenance problems, fixes.
Old 09-28-2001, 01:29 AM
GoodJuan's Avatar
GoodJuan GoodJuan is offline
Send a message via AIM to GoodJuan
Question P10 having getting access to shifter...
I got as far as to get the center console off, but i could't take this plate off around the shifter. It looks like it's bolted in with two nuts up top...at the bottom i couldn't figure out how to remove it. Anyone know what i'm talkinga bout?
They should have kept Dr. Katz on the air.
Old 09-28-2001, 06:48 AM
P10DET's Avatar
P10DET P10DET is offline
If you are installing a short shifter or otherwise removing the shifter, you have to work from the bottom. You will have to unbolt the cat from the header or exhaust downpipe. You will also have to remove the heat shield. Be careful removing these nuts. The studs are small and fragile. If you have any rust and you snap these studs you're screwed.
If you are installing a short shifter, you will have to dent in the top of the heat shield or the SS may hit the heat shield. Be sure to reinstall the heat shield.
There are several good write-ups on short shifter installation on various SE-R sites.
George Roffe
Houston, Texas USA
00 328i
91 SE-R (well modded)
84 944 SCCA ITS race car under construction
"I fear all we have done is to awaken a sleeping giant and filled him with a great resolve"
-- Admiral Yamamoto, December 7, 1941
Old 10-02-2001, 10:10 PM
JustinP10's Avatar
JustinP10 JustinP10 is offline
Send a message via ICQ to JustinP10 Send a message via AIM to JustinP10 Send a message via Yahoo to JustinP10
I will second that... the install is a major pita... just due to the room you have to work with. If you can, i would HIGHLY recommend dropping the exhuast... I didn't and just worked around it (as i couldn't get the second O2 sensor off) and it was kind of a pain. But the rewards are nice, so it was definitly worth the pain.
Justin McClanahan
95 G20
15.4 @ 91.4mph (2.4 60ft )
143.7whp and 131.4 ft.lbs
Primera (10:1) Intake Cam, HS CAI, HS Header, UR Pullies, 19* Timing, ACT, Lightened Stock Flywheel, GC/AGX, Pacesetter Short Shifter, and more stuff...
