Old 12-18-2002, 08:42 PM
RedRacerCivic's Avatar
RedRacerCivic RedRacerCivic is offline
Send a message via AIM to RedRacerCivic
I have a new enemy.
Yes thats right, THE CRANK PULLEY BOLT. I am in the process in putting a VTEC oil pump in my car and the crank pulley just won't come off! So far on my list i broke 2 1/4 inch extensions, 1 1/2 inch extension, bent one ratchet, and broke off a large piece of metal off my tranny housing(using the flathead screwdriver method). I've also spent about 30 minutes trying to use the 1/2 inch impact air gun on the bolt with no budging. So i've been a week without a car cause i can't get this bolt off.
This is a heads up for you who are trying to do this at home. I suggest for you guys to go to a mechanic shop and have them use a 1" impact on the pulley bolt. Thats what i had to do last time to get it off, now i gotta go back again. :o
-1991 Civic Si (Sold)
-1990 Accord EX(Sold)
-2000 Civic Hatch
-1998 Lexus SC300
Click here to see my Shoe!
Old 12-18-2002, 08:50 PM
plkelley's Avatar
plkelley plkelley is offline
Send a message via AIM to plkelley
mine wont come off either, and i also have a long list of broken tools
Old 12-18-2002, 08:52 PM
kris's Avatar
kris kris is offline
Off playing with fire.
Pulley bolt =
Old 12-18-2002, 08:56 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
you know i got the same problem right now. i got my socket on there, extension, breaker bar, 4 foot pipe on the breaker bar. my breaker bar was bent so much, i thought it was gonna snap in half. i even put an impact on it. same thign with me when i tried to jam a screwdriver in the flywheel. i kinda just gave up. idk what to do anymore, oh and right now my car is on jackstands so i cant take it to a mechanic.
lets just say, a belt broke and i bent all my valves, hope i get my b18a pretty soon, i am civicless rigth now
Old 12-18-2002, 09:01 PM
plkelley's Avatar
my uncles gonna help be take mine off. hes got this tool that is more or less just a super heavy duty belt that tightens down around the pulley and then wedges against the ground, the pulley absolutley will not move an inch. then he has the largest impact sockets known to man and a six foot steel bar.....that sucker is coming off or breaking one.
Old 12-18-2002, 10:31 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
For a second I thought you guys were talking about rust, but yes some of these things can be a bitch to do with out the proper tools
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 12-18-2002, 11:51 PM
Killa_CRX's Avatar
Killa_CRX Killa_CRX is offline
When Civics Attack!
I would say try heating the bolt with a torch... but don't burn anything...
Leave some WD-40 sitting over night perhaps?
Honda Enthusiast
Old 12-19-2002, 10:01 AM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
...the first time I had to do this I was doing a mini-me....had the whole damn head off and all that...couldnt get it off...had my friend bring his gun from his shop...wouldnt do it... went back and got his boss's gun...wouldnt budge..... put the whole damn thing back together..drove to his shop..hit it with the small gun and came right off....hand tightened it and drove home... guess I didnt have enough air pressure.. bah..
second time, zc on a pallet....couldnt get the damn thing off.....me being ghetto, decides I'm just gonna hack up the bottom of the timing belt cover with a dremel and pull the cover up and out from behind the pulley..it actually worked I got the belt on no problem....i half ass covering the hole in the bottom of the cover and never had a problem hehe...
anyway, those are my stories...go to a shop
SOLD!
Old 12-19-2002, 06:32 PM
plkelley's Avatar
dont heat it with a torch. the crankshaft is heat treated to be stronger if you heat with a torch you can weaken it
Old 12-19-2002, 08:07 PM
civicracer_1990's Avatar
civicracer_1990 civicracer_1990 is offline
fuck it heat that bitch.......9times out of 10 a shop does do.......I know many many shops that do it......even straight a.s.e. certified........I never have a problem taking mine off cuz I've done it so many times.......oh yeah.....what the hell is "vtec" oil pump........they are all the same dude......trust me ..........I researched it.......goto your honda dealer and they'll tell ya the same.......big waste of time if you ask me....50psi@3000rpm thats a d-series oil pump.......
"Faster and Faster until the thrill of speed overcomes the fear of death" Dr. Hunter S. Thompson
Old 12-19-2002, 09:01 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
get some liquid wrench that has helped me alot in the past, it wont like make a huge difference but it can make a difference
2002 Acura TL Type S
1991 Honda Crx Si
Old 12-20-2002, 12:05 AM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
your honda dealer has a special tool the fits inside the large hex shape hole in your crank pulley, and large enough impacts that will break the bolt loose, do like marked 01 says get it broken loose and hand tighten it to take home...
gunnmen01
kris ...............Pulley bolt =
..............OMG i never laughed that hard.......
My other ride..... is YOUR MOM !!!!!!
Old 12-20-2002, 02:49 AM
Well i got the bolt off...i took it to a mechanic and they had to bust out a 3/4 inch impact that took it off in a couple seconds.
Civicracer, the reason why i am putting a "vtec" oil pump is because the one in my car took a crap on me, it starting leaking oil through what looks like a crack in the housing. So if it breaks, upgrade it! And yes there is a difference in the (D16z6)vtec oil pump vs. the non-vtec (D16a6).
D16a6 : 11.6 gallons/minute@ 6,250RPM Part# 1500-P06-A01
D16z6 : 11.9 gallons/minute@ 6,000RPM Part# 1500-P06-A02
Even though its .3 gallons more at lesser RPM, it should still help out at higher RPM applications...
-2000 Civic Hatch
-1998 Lexus SC300
