Old 12-18-2002, 11:53 AM
york2600 york2600 is offline
Send a message via AIM to york2600
What to do to engine before swapping in
I've heard the basic work you want to do to an engine before swapping it in is replacing the fluids, water pump, and timing belt. Is there anything else I should be doing to swap a JDM B18C into a 94 Integra GSR. Are aftermarket motor mounts worth it? New thermostat?
-Tim
94 Integra GSR Coupe
Mods: Professionally Built B20/VTEC: B18C1 head w/ pocket port, JE oversized pistons, Eagle Rods, block guard, ARP head studs, Skunk2 Intake Manifold, STR Throttle Body, AEM CAI, AEM Fuel Rail/Regulator, RC Engineering 280CC injectors, Denso Iridium Plugs, Magnacor Wires, DC Sports 4-2-1 SS Header, Greddy Evo Exhaust, ACT Stage 1 clutch W/ ACT flywheel, Apexi SAFC & Revspeed Meter, and many other toys.
Old 12-18-2002, 08:25 PM
maxspeedhonda's Avatar
maxspeedhonda maxspeedhonda is offline
Send a message via AIM to maxspeedhonda Send a message via Yahoo to maxspeedhonda
I used the hasport mounts for my swap which i would recommend. One thing i would tell you to do before putting in the motor is check the clutch/flywheel condition. Those motors that are used are not guaranteed to have all new parts. I had to drop my tranny 3 months later to replace clutch. Everyone will tell you if you have the oppurtunity while the engine is out, then at least check it out. Also consider upgrading the axles.
Old 04-13-2004, 03:00 AM
Neronian Neronian is offline
Re: What to do to engine before swapping in
I am planing to do a swap (h22) on my accord 97. I am about to by a new mugen thermostat and fan switch but not sure weather to get them for h22 or accord engine.
Please help...
Old 04-13-2004, 04:52 AM
jcrx jcrx is offline
Send a message via AIM to jcrx
Start your own thread, and logic would dictate that if you are swapping in a H22, you would no longer need any engine parts for the Accord.
Old 04-13-2004, 11:59 AM
Tranzlogic Tranzlogic is offline
Send a message via AIM to Tranzlogic
im with maxspeed..check out your engine and minor internal parts well.. Go ahead and throw a quality mount kit in such as teh hasport..its always a good idea. And as far as the fluids..do not put any oil or other fluid in until your engine is fully bolted and hooked up..you dont want your fluids splashing around your internals and running all over the place while trying to install ! trust me it will be alot easier to fill her juices up after install
Old 04-13-2004, 04:16 PM
Re: Re: What to do to engine before swapping in
I am a newbie at swapping the engine and I have been doing research and there are a few about threads on thermostat. and I posted the question because the tread is about "What to do to engine before swapping in"
Beside the question that I posted, was for maxspeedhonda. He seem to be every in the forums and share his knowledge with other people.
If you do not want to share your knowledge with another people or help another poeple out that is fine with me.
The answer to my question that I posted on this thread is very simple. yes or no
Old 04-13-2004, 05:03 PM
if your really mainly that worried about a thermostat then just go to autozone and buy a new one for 12 bucks..but the one in there in fine im sure
Old 04-14-2004, 12:52 AM
Re: Re: Re: What to do to engine before swapping in
Well you ingrate, you got your damn answer, and you can get answers specifically for your questions when you make a thread of your own. Not to mention, why would you think you needed a thermostat for a F series, when you are swapping it for an H? It's just simple logic.
Old 04-14-2004, 10:03 AM
Re: Re: Re: Re: What to do to engine before swapping in
It is not that I am ingrate. but swaping h22 into acrrord you use some parts from F series to swap the engine. I just want to make sure that I buy all the right parts before doing the swap. I am not a mechanic and sometime I got confused from doing all the research. Now that you mention "why would you think you needed a thermostat for a F series, when you are swapping it for an H? It's just simple logic" It all makes sense to me now.
Being a newbie get frustrated sometime. You start a new trade and hope to get some answer then some guy post "do more research". You do more research and find nothing. What do you do? Post your question on other people thread and hope sompeople will answer your question.
Thank you jcrx for clearing all the questions that I had.
Old 04-14-2004, 10:12 AM
its cool man, hey i know for newbies around the whole automotive mechanical world it is hard to get answers or steps that arnt confusing being that you dont know alot of terminology and so forth...If i am not mistaken HAYNES is releasing manuals now on engine swaps for popular import applications. It should be a step step for dummies sort of speak manual on entire swaps..check out thier website or look around places like pep boys and so forth...good luck buddy
Old 04-14-2004, 10:21 AM
Hey thanks for the info. I will stop by at pep boys to get the book sometime today.
Thank again
Old 04-14-2004, 10:33 AM
not a problom man, if ya cant find it there..check thier website
Old 04-14-2004, 05:45 PM
DeleriousZ's Avatar
DeleriousZ DeleriousZ is offline
Send a message via MSN to DeleriousZ
why exactly does he need new engine mounts? it's almost the same engine he's swapping in... so wouldn't the stock mounts work fine?
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
Old 04-14-2004, 05:58 PM
Need and would want to are not the same. The HAsport mounts are solid and a good addition for helping stabilize a motor in a bay under harsh driving.
Old 04-15-2004, 08:47 AM
Exactley, and once again you will always get what you pay for. It is very helpful to have solid mounts once you get into modifying the motor.
