Old 12-15-2002, 08:51 AM
Thieutje Thieutje is offline
Special Doorsystem ???
Special Doorsystem ??? (this post)
Does anyone have pictures where you can see the doorsystem from this car ?
http://www.fastandfuriouseast.com/ga...tcasting57.jpg
http://www.fastandfuriouseast.com/ga...tcasting59.jpg
I'm from Belgium and I want that system in my car but I can't find some pictures how the doorsystem is actually created.
I hope somebody can help me ....
Thx a lot !!
Greetz
M.
Old 12-15-2002, 09:03 AM
Zammo's Avatar
Zammo Zammo is offline
not of that system but try contacting hamman they might be able to steer you in the right direction
Two off the best things in the world are duct tape & araldite 95% of the worlds problems can be fixed with them
Want To See The Wildest Cars & Learn How To Make Them Visit www.photo-chop.com or ZTi
Old 12-15-2002, 09:09 AM
I'm sorry but how who do you mean with hamman ?
I don't know any hamman ? Could you give more details please ...
THX m8 !
Old 12-15-2002, 09:40 AM
Zammo's Avatar
Sorry I spelled it wrong its hamann
http://www.hamann-motorsport.de/
Theres a german and an english version
Heres a sample of there work
Old 12-15-2002, 10:11 AM
yes, but that doorsystem is easy to make.
It's the one one the ford mustang cobra that i want and that is not from hamann..
Old 12-15-2002, 10:26 AM
Zammo's Avatar
yes but im sure they can steer you towards who ever does make them
Old 12-15-2002, 02:32 PM
illracer's Avatar
illracer illracer is offline
That particular cobra was done by Street Weapon Composites in so cal. Any really good body shop would probably be able to do it.
www.streetweaponkits.com
Old 12-15-2002, 05:05 PM
Thanx a lot man !!!
Did you actually saw the system in real life ?
Can you give me more information how the system works because i would like to make it on my car.
I from Belgium so that's a long way to come looking.
If you had pics of the car from the inside with the door open so i can see the system It would be much of a help.
Thx a 1000 times man !!! U rule !!
Sincere Greetz
Mathieu
Old 12-16-2002, 04:22 AM
Zammo's Avatar
i have not seen that hamann setup in real life on a car but ive seen it in peices
the one you want is more complicated and there are 2 types
hydralic/mechanical hybrid better if you can afford it i geuss
Mechanical
both acheive the same result but HM has a smoother action
pushing the door away parrallel to the car then rotating it up
i can draw you vague and i mean that literally pics of how each system works but installing them is a nightmare as you have to frame reinforce
inside each door you want to open fron a single pivot
Old 12-16-2002, 07:36 AM
I saw the Hamann door system in real life but that system is really easy to make ( believe me ) cause you just have 1 movement to maintain. I saw the car in Germany Essen Motorshow
Mechanical
I would be satisfied with the mechanical system
That's the problem iI have, Rotating it up is the easiest part but I don't know really how to get the door parallell away from the car ?
inside each door you want to open fron a single pivot.
If you could do that for me I would be very thankful.
Installing is a problem I can try to solve but my problem right now is that i can't see the system in my thoughts.
If you could draw a picture of the system and show me how it opens in different steps I would be the happiest man on earth :flash: :flash: :flash:
THX again for your help man, I really look forward to it ...
if you have msn ===> [email protected]
Sincere greetz
Mathieu
Old 12-16-2002, 08:09 AM
Zammo's Avatar
i will draw you some plans for a hydralic version if you have access to computer Controled Milling Machine you would probably be able to do it your self providing your LAWS allow it
if possible could you tell me what make and model car this is for
and weather its private Personal
private Show
Corporate Show car
Oh and youll have to give me a little time as i have to do my PSJ comp car first
Old 12-16-2002, 09:29 AM
Its for my own personal car ===> Peugeot 306 / 3 doors from 1999.
I'm sorry buth my english isn't that perfect ...
What is Control Milling Machine ? ( never heard such a thing )
is there a great difference between the hydraulic version and the mechanical , because i'ms sure i won't use the hydraulic version so I would be more helpen with the explanation for a mechanical system ( if that's possible).
I think i could make the mechanical system myself if i had the plans about how it works.
By mechanical system i mean a hinge with a pump ( air filled ).
Thank u for your time ... I hope to hear from u ...
Thanx a lot !!!
Sincere greetz
Mathieu
Old 12-16-2002, 09:52 AM
Zammo's Avatar
well yes you should use the hydralic more reliable
using telescopic splines on a gyroscopic pivot
your english is ok for a belgian
und ich kann auch ein bisien deuch sprechen ? if that helps
but with limited english its hard to explain it in terms you could understand
Machines used for billeting alloy & steel ie Wheels Gears Splines
Old 12-16-2002, 10:59 AM
I don't really understand how this hydraulic system works but I think it's very complicated ...
Don't you need extra things ( o don't know the word ) where the oil has to flow through and a pump also ...
is the mechanical hinge system the same with or without the hydraulic or not?
Can you please go on msn if you can ==> [email protected]
Old 12-16-2002, 11:19 AM
Zammo's Avatar
its full and wont accept my e-mail
Here is the message
ok the mechanical system relies on Tension and compresion they are i think harder to open as well as wearing out quicker to engineer one of these you would need to be a mathematical genius or have plenty of time and money to trail and error it
hydraulic systems can be set to open with car alarms\keyless entry systems plus open & close effortlessly to engineer one of these you just make it extra strong and let the hydraulics do the work
Porsche Boxter Special Special Edition~ TRBJ Completed Projects / Gallery 3 12-22-2008 04:31 AM
Special Edition Z? hondacsi 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 14 04-04-2004 06:09 AM
Special Doorsystem ??? Thieutje Mustang Talk 1 12-17-2002 03:31 PM
special SS email addresses richb Chevelle 0 07-03-2001 01:24 AM
