Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 12-13-2002, 09:17 PM
nvs nvs is offline
help on keyless entry 99 lumina
i was wondering if anyone has any info on how to program the keyless remote for a 99 lumina LS.tx in advance!
Old 12-16-2002, 10:12 AM
Shortbus Shortbus is offline
Blah blah blah
Send a message via AIM to Shortbus
Hope this helps you.
Transmitter Programming
Perform this procedure when any of the following conditions exist:
The RKE programming connector (BLK/WHT wire) is grounded (CKT 1455).
The RCDLR is replaced.
A keyless remote transmitter is replaced.
A second (up to a total of 4) keyless remote transmitter is added.
Programming Procedure
Important
If the vehicle has more than one keyless entry transmitter, ensure that all of the keyless entry transmitters are programmed during the same programming sequence. Any keyless entry transmitters that are not programmed will not work correctly.
Open the rear compartment lid.
Pull aside the right side compartment trim in order to gain access. Refer to Compartment Side Trim Replacement - RH Rear in Body Rear End.
Use a jumper wire with alligator clips in order to ground the RKE programming connector. The door locks will lock and unlock. This action indicates that the RCDLR has entered the keyless entry transmitter programming mode.
While the programming connector is still grounded, program each of the keyless entry transmitters, one at a time. Press and hold the LOCK and UNLOCK buttons simultaneously on the first keyless entry transmitter. Hold the buttons for 10 seconds. The door locks will lock and unlock. This action indicates that the keyless entry transmitter has been programmed.
Repeat Step 4 for the remaining keyless entry transmitters. You may program as many as 4 keyless entry transmitters.
Remove the jumper wire from the RKE programming connector terminal.
Verify that the keyless entry transmitters operate correctly.
Install the right side rear compartment trim. Refer to Compartment Side Trim Replacement - RH Rear in Body Rear End.
Close the rear compartment lid.
Old 12-16-2002, 06:09 PM
nvs nvs is offline
i dont want to look stupid here,,, but is that jpeg on the right side of my trunk?and were do i ground the wire to?
Old 12-16-2002, 06:14 PM
Blah blah blah
Standing at the back of the car it is on your right hand side.
you can ground the connector to any unpainted metal surface in the trunk such as a bolt or screw head.
Old 12-16-2002, 06:31 PM
nvs nvs is offline
well i looked in the trunk and moved the lining on the passengers side and i dont see the reciver. can it be somewheres else?
Old 12-17-2002, 07:22 AM
Blah blah blah
Ok I think I know what is going on here. The reciever is not inside of the trunk but it is inside the vehicle underneath the rear package shelf trim panel. Does that make sense? I have a better jpg, the angle is from inside of the car at the back seat you can see where the wiring harness comes up from the trunk to the module. Good luck
Old 12-17-2002, 05:12 PM
nvs nvs is offline
ok, so i have to pull out the panel were the speakers are under . maybe that makes sence! tx i will try that
Old 12-18-2002, 10:07 AM
Blah blah blah
Did U find it?
Old 12-18-2002, 10:39 PM
nvs nvs is offline
yes i did . tx very much! all i have to do is connect the jumper wire that i made.
Programming Keyless Entry for MAZDA 6 Mazda6ownr 6 7 09-26-2013 04:46 AM
1998 Toyota Avalon XLS Keyless Entry Programming Instructions kattate09 Avalon/Pronard 1 02-04-2010 04:58 AM
94 s10 remote keyless entry programing instructions needed stillblazin Problem Diagnosis 0 07-01-2009 09:39 PM
remote keyless entry problem smity9089 Intrigue 0 04-13-2009 11:45 PM
06 Camry LE - How to program keyless entry pshrivas Camry/Camry Hybrid/Vista 0 03-20-2009 02:54 PM
