Old 12-13-2002, 03:23 PM
plkelley's Avatar
plkelley plkelley is offline
Send a message via AIM to plkelley
Need an opinion from you guys
Alright. Seeing as how I have never driven my car and that I have just recently got it running, I really dont know what all it needs yet. I just removed the exhaust manifold to get it fixed so I know im changing that gasket. I also know that the valve cover gasket needs changed. So...since all that is pretty much already apart should I go ahead and change the head gasket, and the timing belt since that has to come off too...is there anything else I should go ahead and do while im at it..
What do guys think? Is there anyway to tell if the head gasket needs changed without running the car?
Old 12-13-2002, 03:25 PM
91zc 91zc is offline
Water Pump
Thermostat
Any old hoses
Distributor cap and rotor
Spark plugs and wires
That is all I can think of for now. If you have the head pulled just replace the head gasket since it is not a good idea to re use an old one.
91 civic 4dr
b16a
14.8@94
Old 12-13-2002, 04:07 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Also, check your oil filter, air filter, and fuel filter...
Old 12-13-2002, 05:09 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
might want to think about ringing it as well, since you'll have the head off its only the oil pan bolts to drop the pistons out that wya you'll have a fresh motor in it...
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 12-13-2002, 05:13 PM
plkelley's Avatar
Well...that would definetly be the way to go..although the complete gasket sets are like 200 bucks.
Old 12-13-2002, 06:02 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
when i had my headwork done it came to 400 sumthin including parts/labor and i dont think the gaskets costed 200 bucks and it was a complete set, i had gaskets to things i had no clue where they went, oh and headbolts were 100 bucks from honda
2002 Acura TL Type S
1991 Honda Crx Si
Old 12-13-2002, 06:33 PM
Xenostalgia's Avatar
Xenostalgia Xenostalgia is offline
Send a message via AIM to Xenostalgia
Make sure it has gas.
Old 12-13-2002, 07:24 PM
plkelley's Avatar
Do you have to replace the headbolts?
Old 12-13-2002, 07:50 PM
jeef jeef is offline
Send a message via AIM to jeef Send a message via Yahoo to jeef
Have to no... supposed to yes... they stretch
90- crx si w/ a D16a Vtec and a few goodies, oh and 60k miles on it heh
Old 12-13-2002, 08:16 PM
plkelley's Avatar
Oh...well that kinda sucks..I think im gonna just change the valve cover gasket and exhaust manifold gasket and then find out what it really needs when I can run it.
Old 12-13-2002, 09:07 PM
kris's Avatar
kris kris is offline
Off playing with fire.
Dang, I just picked up ARP head bolts for $60.
