Old 12-12-2002, 07:48 PM
CivicEXdude CivicEXdude is offline
Header or Pulleys?
I have about $200 to spend, would I benefit more from a Header or Underpulley kit? I have 2000 EX with AEM CAI, full exhaust...
Old 12-12-2002, 07:55 PM
YOUNGSTER YOUNGSTER is offline
Send a message via AIM to YOUNGSTER Send a message via MSN to YOUNGSTER Send a message via Yahoo to YOUNGSTER
id go with pulleys im not even sure if thats enough money but yeah go for the pulleys especially if you plan on going turbo.
Old 12-12-2002, 10:09 PM
Thats what I was thinking - will probably go turbo later - wonder if pulleys are hard to install? or cost much to have put on? You can find AEM kits for like $140 online...
Old 12-12-2002, 10:35 PM
shawn1 shawn1 is offline
If I was you i would go with the pulleys because you can't get a descent set of headers for 200 dollars. Your gonna spend more than that on the pulleys if you don't put em on yourself. If you had about 75 dollars more i'd go with the headers because I have headers and pulleys on my car and i noticed a bigger difference with the headers and they are also lighter than the stock manifold, it looks much cleaner, it adds more horsepower, and it would be easier for you to put the headers on yourself(except for those stuborn bolts). <-Use pb blaster for those.
Old 12-13-2002, 09:37 AM
Did you put the pulleys on yourself? If so, how hard was it? If not, how much did it cost? Did you feel anymore torque/hp from it?
Old 12-13-2002, 05:54 PM
Well first I went somewhere to get a estimate and they wanted like 300 bucks, so I ended up doing it myself and it was a pain in the A@#. First we couldnt some of the nuts off cuz the pulleys turn too, then when we got the nuts off some pulleys were stuck, and then we had to use a harmonic balancer to put the dang things back on.Oh yeah and its also hell getting to all the pulleys.You'll probably endup taking the front right wheel off. I noticed a difference, but I dont think it was worth it. You might be better at it than me though.
Oh yeah i probably would have went a lot easier if we would have left the belts on as long as we could to hold the pulleys still.
Old 12-13-2002, 10:11 PM
Tominos Tominos is offline
why not just use a pulley wrench to hold the pulley still? i recommend saving up for headers, because honestly, pulleys doesn't do jack. in my experience.
Old 12-14-2002, 12:28 AM
yeah id go pulleys why was 350 on header just to get rid of it later id go with the unorthadox racing pulleys i think the ss set its like 300 plus install it should be worth it.
Old 12-15-2002, 01:39 AM
j_knobel j_knobel is offline
What do you mean the pulleys don't do jack? Import Racer ( I believe ) did a dyno test or the unorthodox racing pulleys on a 240sx and got about 8 ft/lbs of torque throughout the entire power band and 3-7 hp, the higher it reved the more the engine benefited. Headers (depending on design) might give you more top end, with a slight loss of torque. Go with the pulleys and a straight pipe!
Old 12-16-2002, 03:30 PM
Frostbyte Frostbyte is offline
Send a message via ICQ to Frostbyte
Doyou plan on keeping your A/C and your P/S? If you are going to be pulling that out then it would be better and cheaper and you would get more horses if you went with the UR Race Crank Pulley. That is what I have and I noticed a big diffrence.
1989 s13 Fastback
Tein HE coil-overs
sr20det swapped!
JIC Magic Front and Rear Strut Bars
Slotted and Cross-drilled Rotors
S/S Brake Lines
Pivot Lazy eye controller
Blitz LM Intake
Blitz D1 Spec Turbo Timer
Soon to come:
Sard 550cc Injectors
Blitz Nur Spec Exhaust
Blitz Down pipe
HKS FMIC
http://www.driftmonkey.com (Part Owner)
Old 12-17-2002, 09:52 PM
I will be keeping my AC and power steering, so thats why I was thinking to go with the pulley kits...
