Old 12-12-2002, 06:39 PM
shawn1 shawn1 is offline
Black smoke with downshift
I was wondering if anyone has this similar problem and if they do what does it mean. I have a apex'i n1 catback which i think might make the smoke more obvious. It only does this whenever i take off real fast or shift at high rpm's. Everyone tells me when i'm racing that when i shift into second a black cloud of smoke shoots out. I wanna know who else this happens to or is it just me?
Old 12-12-2002, 07:09 PM
Frostbyte Frostbyte is offline
Send a message via ICQ to Frostbyte
My car does that as well. I wouldnot worry about it. They are just Carbon Deposits blowing off.
1989 s13 Fastback
Tein HE coil-overs
sr20det swapped!
JIC Magic Front and Rear Strut Bars
Slotted and Cross-drilled Rotors
S/S Brake Lines
Pivot Lazy eye controller
Blitz LM Intake
Blitz D1 Spec Turbo Timer
Soon to come:
Sard 550cc Injectors
Blitz Nur Spec Exhaust
Blitz Down pipe
HKS FMIC
http://www.driftmonkey.com (Part Owner)
Old 12-12-2002, 10:26 PM
Oh Aiight thanks man i was kinda worried. Well i guess it's not too bad then except for the fact that it does not look that cool.
Old 12-13-2002, 10:15 PM
Tominos Tominos is offline
u could be burning a little bit of oil. my friends mr2 does this too.
Old 12-14-2002, 01:19 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
if your burning oil then blue smoke would come out.
could it be your cat ? maybe its old and getting clogged, idk just a guess.
Old 12-14-2002, 07:41 PM
Yeah actually it could be the catalytic convertor because thats the only part of my exhaust I haven't replaced yet. I think its that and carbon deposits in my exhaust because i usually don't get the gas too much and when i do i think it's kinda cleanin it out. <- A good excuse to speed and accelerate real fast.
Old 01-03-2003, 06:29 PM
The other thing that it could be is a bad 02sensor in which your check engine light would be on or your fuel is running rich. But I bet it is just Carbon Deposits.
1989 s13 Fastback
Tein HE coil-overs
sr20det swapped!
S/S Brake Lines
Blitz LM Intake
Soon to come:
Blitz Down pipe
HKS FMIC
Old 01-30-2003, 02:53 PM
mastr/of/pupets mastr/of/pupets is offline
If there is dark smoke coming from your engine, this is not good. The smoke is a sign that oil is getting in your cumbustion chamber. Not Good!!! Your valves could be warped. More than likely your oil seals are warped and are leaking oil. Anyway you look at, your engine is in need of maintanence. Its show its age.
Old 01-30-2003, 03:01 PM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
If its just carbon you gotta clean out the inside of the muffler it'll probbly also give you one thousandth of a horse lol
Old 01-30-2003, 03:05 PM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
I'M BURING OIL BAD...I REFILL ABOUT ONCE A MONTH NOW B/C I'M USING 20W 50
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 01-30-2003, 09:54 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Lightbulb
If you don't know what you are talking about please don't respond with false info when you don't know if it is true or not. Someone might take your advice and it be wrong which in this case it is!
burning oil= blueish smoke
burning coolant= white smoke
running rich = black smoke
Try doing tune up stuff like plugs, air filter, running some injector cleaner etc. All of these things can cause a engine to run rich if in need of replacement or cleaning.
