Old 12-12-2002, 04:33 PM
turbcivic's Avatar
turbcivic turbcivic is offline
Ahh shit
Time for me to complain. I relized my car is about to blow up. My cars get a clunking sound in front that goes away when i hit the gas in gear and clunks with the wheel rotation. My car is missing when i hit the gas in the lower RPM. My tire has a 1/4" groove cut on the inside of the tire and i can't figure out were it came from and no, it's not from negative camber. My car is shooting out smoke when i hit the gas, maybye a brunt vavle or piston rings. Also, my car shoots out gas and black shit when i punch it. Is it just me or does my car suck?
Old 12-12-2002, 04:48 PM
1.5 liter 1.5 liter is offline
Send a message via Yahoo to 1.5 liter
i think ur car is blowing up
Old 12-12-2002, 05:34 PM
MKS MKS is offline
my car spits out unburnt fuel too hehe aint noticed a drop in performance yet mind u its been doing it since i added all my mods.. so its been liek ti for a bit now...
1989 Toyota Supra 3.0i Turbo
150mph I think I'm nuts
Custom S/S Exhaust 5" Tailpipe
K&N Induction kit
Bailys Piston Dump Valve (WOOSH)
Wategate Shimmed by 5mm ummm boost
Old 12-12-2002, 06:20 PM
Marc-OS's Avatar
Marc-OS Marc-OS is offline
Send a message via ICQ to Marc-OS Send a message via AIM to Marc-OS
Re: Ahh shit
Good way to test for burnt valves would be to hold a dollar bill up to the exhaust, if you can see the dollar being pulled towards the exhaust, you got a burnt valve.
10 PRINT "MARC-OS 0WNZ J00!!!"
20 GOTO 10
RUN
4/8/04 - My CRX is officially dead, RIP Lucy
Old 12-12-2002, 06:29 PM
tenzoracerevovii tenzoracerevovii is offline
i think you gotta check your axles for the clunking sound that you said. it's not very expensive to fix that. my aunt got her integra axle fixed for 150 bucks.......
i have type-r stickers on my bike, will it go faster?
-me
Don't you know, it's 10 hp for every sticker, 50 hp extra for every additional inch of rear spoiler behond stock height.
-obiewancoyote
Old 12-12-2002, 10:09 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
sounds like your motor needs a rebuild...badly.Luckily the 4th gen motor is probaly the easiest to rebuild... in the car or out of it.
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 12-13-2002, 04:00 PM
turbcivic's Avatar
Re: Ahh shit
I found my problems after i calmed down and put it on a lift at work. First the clunking noise was from my driver side tire that two of the lugnuts had fallen off so on went the steelies. The second problem was my Temp. sensor was acting up and making my car idle weird. The third is i have a bad head gasket. So on saterday, on goes a new gasket and a T-belt package while im at work. See it wasn't all that bad. I feel a little bit happier now.
P.S. Do all the work myself and the total cost is gonna be $250, 102 for t-belt package and 135 for head gasket set.
