| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
Coilovers Vs Lowering Springs
i previously started a thread about the bounce in my car and got help with that, but now i need more help. i don't know which one to get...coilovers or lowering springs. which one is better and/or which one is the best for my 1990 Civic HB
The name's Adrian 1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills 1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills 1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills 2006 G35 Coupe 6MT - Stock 2011 CR-Z - Stock |
you'd prolly be better off with the coilovers can at least you can adjust them to your desired ride or show hieght.
you can slam your car while you park at a show or something, then raise it up when your cruising around. id get em.
Name: Scott Stable Of Cars I have Owned: 1991 Honda CRX 1990 Oldsmobile Cutlass Supreme 2003 Honda Accord 1998 Chrysler Concorde 2007 Honda Civic 1997 Toyota Camry 1995 Saturn SC2 1996 Ford Taurus 1991 GMC Sierra 2002 Daewoo Leganza 1999 Dodge Ram 2007 Honda CR-V 2003 BMW 325i |
WELL RIGHT NOW I DRIVE WITH MY COILOVERS SET ALL THE WAY DOWN, BUT NEED A BETTER QUALITY SET OF SPRINGS, BUT INDECISIVE BECAUSE I'VE HEARD THAT LOWERING SPRINGS HAVE A BETTER RIDE.
idk about anyother state but my state has recon, which does not allow coilovers but alllows lowering springs. does any other state have this, if your state does you may wanna check out what you can put on your car.
i like my coilovers, you can adjust it |
id go coil overs. ive heard there good ive heard some bad things about lowering springs
what have you heard?? need to know b4 i spend any money
i plan on getting: neuspeed front & rear sway bars neuspeed lower rear tie bar neuspeed front upper strut bar neuspeed race springs and kyb 4-way adjustable agx struts but if i get coilovers, i won't need the struts and springs. if i get coilovers, will probably get neuspeed but was looking at some spoon coilovers today. not that expensive. still not sure which one to get
i was also told that every time you adjust your coilovers either up or down, you 've gotta get an alignment done
Are you talking about true coilovers or coilover sleeves. If you are talking about sleeves I would go with the lowering springs. If you have your mind set on the coilover sleeves i would get ground control with some koni yellows. I have sprint springs and koni yellows on my car now and it rides like stock, but corners like lowered.
If you're looking to go full true coilovers, seriously consider Tein, I have them on my Civic coupe, and I couldn't be any happier with them, they have a better ride feel and comfort than almost any springs/shocks I've ever felt. Plus you can make them feel soft as stock, or bouncy as Tigger.
![]() And yes, generally whenever you adjust the height up or down, you'll most likely need an alignment if you don't want your tires to wear out about 50 times faster than normal.
Silver '00 Civic EJ6 Coupe PureHonda original member since Feb. 2000 D-series revolution For pics of my baby, click here! All rights reserved... All BITERS served! "The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket." i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift hessemer69 on AIM |
yes i am going for the full coilovers. doesn't tein make the ones that you can adjust from inside your car?? when i say those i wanted those. i think that i might go for the full coilovers instead of the springs because i can raise or lower. i think that if i don't go cheap on them (i.e. my aerospeed coilovers) that i'll have a smoother ride. is tein the best brand for full coilovers??
THANX SilverY2KCivic FOR THE INFO ON TEIN. DECIDED TO GO WITH THEM AND I'M ALSO GOING TO GET THE EDFC FOR THE COILOVERS. THAT'S GOING TO BE SWEET :smoka: NOW GOTTA FIND A PLACE TO PUT THE EDFC
ive heard from friends that lowering springs sag and bounce after a while
is that what you've heard for cheap springs or just all of them
ive heard after time not to much that most do it hey but maybe im wrong
bad thing with coilovers is sometimes you cant get it perfect and then it leans to one side. sucks and people laugh, nay on coilovers, ya for springs
