Old 12-12-2002, 01:15 AM
jrgcivic jrgcivic is offline
Exclamation help with throttle body
I just installed a BBK throttle body. Worked fine then it started reving. It revs on and off from 2 to 3. Why is this? Please help.
Old 12-12-2002, 08:07 AM
yougod10 yougod10 is offline
Send a message via AIM to yougod10
It did come with its own map sensor and tps right? Just check to make sure those 2 connectors arent switched. And make sure your codes are reset by pulling the "backup" fuse for about 10 seconds and putting it back in. Then assure that your throttle cable is not too tight.
www.nexusmotorsports.net
Old 12-12-2002, 08:31 AM
shawn1 shawn1 is offline
HAve you checked to make sure you don't have a vacuum leak or something, or maybe air is being sucked in around the throttle body. If I was you i would get like some wd40 and spray around and see if it stops. This might help, I'm not real sure.
Old 12-12-2002, 01:18 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
sounds like an air leak to me also, but first check your connections, then spray water around the outside of the TB where it contacts the runners, if you see bubbles form, then you have a leak.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
