Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 12-12-2002, 12:37 AM
fatmatt fatmatt is offline
Send a message via AIM to fatmatt
Question programming keyless entry for 98 gmc suburban
I found out that you have to pay $25 to program one transmitter at the dealership. what a rip off! I was wondering if someone could tell me how to program with out screwing up the keyless remote system. i believe my suburban has tech 2 (honks after second press of lock button)
Thanks, Matt
Old 12-16-2002, 10:20 AM
Shortbus Shortbus is offline
Blah blah blah
Send a message via AIM to Shortbus
Hope this helps you.
Transmitter Programming
If they key is in the ON position during the programming procedure, the horn chirp will be disabled, if the key is in the OFF position, the horn chirp will be enabled. The horn will chirp when the lock button is pressed two times.
When reprogramming the remote control door lock reciever, All transmitters must be programmed at this time in order for the transmitters to operate the vehicle. Transmitters not programed at this time will not work and the procedure will have to be redone with all the transmitters.
Ground pin 4 to pin 8 of the data link connector (DLC). The receiver will respond by locking and unlocking the doors, and activating the liftgate window release (if equipped) within 2 seconds.
Press and hold the LOCK and UNLOCK buttons simultaneously on the first transmitter to be programmed until the locks cycle (approximately 10 seconds).
Repeat step 2 for up to four total transmitters to be programmed (if available). The receiver will respond by locking and unlocking the doors and activating the liftgate window release (if equipped) within 2 seconds.
Remove the ground applied to the DLC.
Lock and unlock the doors in order to verify the transmitter operation.
Activate the rear window release in order to verify the transmitter operation
