View Poll Results: b18c1 or h22?
b18c jdm 180hp 129ft lbs torque less weight 2 66.67%
h22 jdm 200hp 161ft lbs torque more weight 1 33.33%
Voters: 3. You may not vote on this poll
Old 12-11-2002, 06:35 AM
vtgsrcivicboi vtgsrcivicboi is offline
Banned
Question Need Advice
Ive been thinking really hard lately wheather to get a jdm b18c or a jdm h22 i understand that the gsr has 180 hp stock with about 129 ft lbs of torque, the gsr will cost me 3800. The h22 has 200hp stock and about 161 ft lbs of torque but it weights more then they gsr can anybody tell me which one is better i seen alot of gsr's spanking h22's but if i put it in my hb its much lighter then the base model prelude. can anybody show me a fact on both tests of a gsr civic vs a h22 civic and what the outcome was? thanks
Old 12-11-2002, 07:27 PM
maxspeedhonda's Avatar
maxspeedhonda maxspeedhonda is offline
Send a message via AIM to maxspeedhonda Send a message via Yahoo to maxspeedhonda
I believe they would be very close. I have the b18c in my car. I was considering the h22a but after lots of research i found out some of the following things. H22A's are perfect for accords but have some downfall in a civic. The h22a is postioned different than the b series in the engine bay, which tends to result in huge under/over steer meaning you will have a car thats fast as hell in a straight line but will not corner well at all. You will definatley need custom mounts and maybe some firewall work. Also consider t you ecu version. You will definaltley need some other axles, as i killed mine with my swap. Because of the size of the motor itself, it will actually hang below the rest of the cars frame. If you bottom out you might have a very serious problem. My suggestion is to go with the b18c. Its a awesome motor. Also search around on the net and you will find the same facts i mentioned and more.
Old 12-12-2002, 03:03 PM
Beyond Imagination's Avatar
Beyond Imagination Beyond Imagination is offline
There will always be an ongoing debate between the H22 and the B18C. If it was up to me I would get the B18C. Consider the B18C5 as well.
88 Honda CRX Si - B16
90 Honda CRX Si - B20VTEC
Old 12-12-2002, 04:37 PM
Frostbyte Frostbyte is offline
Send a message via ICQ to Frostbyte
Well the H22 is not balanced right it kind of sits over to one side. In which people say that you can adjust your front suspension but person I think it is a little gay when you have one strut in the fron adjust diffrent then the other. Kind of Ghetto but to each their own.
1989 s13 Fastback
Tein HE coil-overs
sr20det swapped!
JIC Magic Front and Rear Strut Bars
Slotted and Cross-drilled Rotors
S/S Brake Lines
Pivot Lazy eye controller
Blitz LM Intake
Blitz D1 Spec Turbo Timer
Soon to come:
Sard 550cc Injectors
Blitz Nur Spec Exhaust
Blitz Down pipe
HKS FMIC
http://www.driftmonkey.com (Part Owner)
Old 12-14-2002, 01:16 AM
YOUNGSTER YOUNGSTER is offline
Send a message via AIM to YOUNGSTER Send a message via MSN to YOUNGSTER Send a message via Yahoo to YOUNGSTER
b18c5 (type r) sucks id either go b18c or h22a if all motor h22a lots of torque id use it for all motor and b18c for turbo either way would be fine do you plan on it being a daily driver or a straight drag car.
Fender Bender - Need Advice on Repairs Panken202 Grand Cherokee | Grand Cherokee SRT8 3 10-24-2010 09:50 PM
82 rabbit may need engine, I need advice gengelman Rabbit 3 05-10-2005 06:52 AM
for sale 95 jetta runs needs work good project or parts car/ need advice for new car scooterman Jetta/Vento/Bora 0 01-03-2005 12:46 PM
a4, need advice, 97 a4, any need to start rust control (krown)?? ssdeluxe '94 - '01 2 02-19-2004 04:29 PM
i need a bmw and need advice needabmw 3 Series 1 03-14-2002 10:46 AM
