Old 12-10-2002, 12:46 AM
4thgenhb 4thgenhb is offline
need advice before buying an LS motor
I have a 89 honda civic hatch... & I found a great price on a LS motor. I'm going to buy it by the end of this week if everything is good on it.
Does anyone have any advice on what to look/check for, like a check list of things I need to look for when I'm checking out an engine. I'm not trying to get ripped off by this guy, so if anyone has any little advice it would mean a lot.
THANKS
4thgenhb
Old 12-10-2002, 01:39 AM
civicracer_1990's Avatar
civicracer_1990 civicracer_1990 is offline
well.......I guess just make sure its all there ...........haha.....I don't know what you are all getting with the engine.....just make sure nothing looks odd or funny...like missing shit or broken/bent stuff........
"Faster and Faster until the thrill of speed overcomes the fear of death" Dr. Hunter S. Thompson
Old 12-10-2002, 04:49 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
yeah just make sure everything is there, remeber you also need the engine tranny axles ecu. make sure it has the tb, fuel rail, injectors. you could pull out the dipstick and check the oil, if it was changed recently and the motor is black, then something is wrong with the engine. you could take off the valve cover and look at the cam for burn marks, which would indicate the engine was ran without oil before. you could take off the oil pan and look for metal flakes in teh oil pan. alot of stuff you can do, but the question is do you wanna take the time and do them.
check to make sure the tb sensor is not broken
Old 12-10-2002, 08:53 AM
tb sensor what's that??? is it throttle body sensor???
i know comes w/ engine & tranny, i need the ecu, axles, mounts and something else i forgot what my friend said.
also i was reading on civicland.com that for any b18 engine i have to change my front end and get a new hood to make the LS motor fit. is that true??? is there any other mods i need to know about???
THANKS for responding this helps me a lot
Old 12-10-2002, 09:21 AM
Jmunk Jmunk is offline
Send a message via AIM to Jmunk
You don't need to get a new hood. It will fit fine with your stock hood. Your going to need to buy a mount kit for it. You'll need to modify your shift linkage for it to fit the tranny right (chop about 2 inches out), you'll to have your exhaust modified to accept the B-series header, the holes don't line up at the cat. Not really too much if the price is right, i would really check with the guy on the mileage, how the clutch was, your probally going to want to change the timing belt, water pump, maybe oil pan gasket while it's out and other little things like that, they can add up quick too. Oh you'll also need the axels.
Old 12-11-2002, 01:26 AM
i made a list of what to check for. I'm going to check out the engine hopefully Thursday. Thanks for all the advice, I really appreciate it.
4thgenhb
Old 12-11-2002, 04:44 AM
yeah throttle body sensor, sometimes people dont take off the throttle body when taking out there motor and they accidently break the tb snesor.
Old 12-11-2002, 04:10 PM
kris's Avatar
kris kris is offline
Off playing with fire.
ack, I did that. Nothing a little super glue and solder didnt fix.
Old 12-12-2002, 05:29 AM
SkyNex721's Avatar
SkyNex721 SkyNex721 is offline
Send a message via AIM to SkyNex721
If you cut the shift linkage and reweld it, make sure you do it right. Cause if you don't you'll mess up the synchros.
R.I.P. - You shall be resurrected.
Old 12-12-2002, 08:33 AM
Could I buy a shift linkage that's 2 inches shorter/ would fit my car??? How much would a new shift linkage cost me???
Old 12-12-2002, 10:02 AM
Killa_CRX's Avatar
Killa_CRX Killa_CRX is offline
When Civics Attack!
Either HASport makes a linkage to be used with their mount kit, or hcp engineering makes an adjustable one. I believe they both sell for about the same price.
www.hasport.com
www.hcpengineering.com
Honda Enthusiast
Old 12-12-2002, 10:11 AM
91zc 91zc is offline
You will also need a drivers side mount bracket from a 90-93 integra so you can use the hasport, hcp or place racing mount kit.
91 civic 4dr
b16a
14.8@94
Old 12-12-2002, 01:38 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Are you talkin about the "t-bone" bracket? I thought it was in the rear? Anyways what year is the ls motor from?
Old 12-12-2002, 01:56 PM
mellowboy's Avatar
WARNING: stay away from place racing shift linkage!
Old 12-12-2002, 02:32 PM
No the drivers side mount bracket that is mounted to the block is different than the early b series motors. The bolts sit side by side on the new b series brackets while the older ones sit on a diagonal. Therefore to use the 4th gen mount kits on a newer bseries motor you need the early drivers side mount bracket.
91 civic 4dr
b16a
14.8@94
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
