Old 12-09-2002, 09:29 PM
Project88HB Project88HB is offline
Timing Belt
well after tyring so many things, i figured out why my car wont start, my timing belt is bad, anyhow i was wonmdering, how hard is it to remove and put ona new one? i really dont feel liek paying 300 bucks for labor,help is appreciated, thanks guys! =pand what exactly do i need to do.
I believe that we should make the world a better place for our children, but not our childrens, children because children shouldnt be having sex...
Old 12-09-2002, 10:09 PM
Jmunk Jmunk is offline
Send a message via AIM to Jmunk
You think it's bad ? Did you hear a loud snap sound when you were driving ? Did you pull the cover off the cam gear and see if the belt is broken ? Are you getting spark ? The belt isn't that hard to change, but if the belt broke theres a chance that it could have took out some valves when it broke. Honda motors are interference motors and when the timing belt breaks theres a chance that the valves and the pistons may meet. If that happened than your timing belt just got expensive. If you got lucky and the belt broke and didn't bend any valves than it's not that hard of a job to do. I would also reccomend for you to change your water pump while your in there. The hardest part of the job really is breaking the crank pulley bolt loose. Go and get yourself a Helms or chiltons repair book to help you. You'll want to set the #1 piston to top dead center a(TDC) and line up the cam gear, slide the new belt on. Not that hard. I can do it in like a hour and a half.
Old 12-10-2002, 12:41 AM
91civicDXdude's Avatar
you also forgot about having to remove the drivers side engine mount. you cant get the timing belt on without removing it, or atleast i could not.
Old 12-10-2002, 07:16 AM
turbcivic's Avatar
turbcivic turbcivic is offline
HAHAHA, sorry but i love this part. IF your timing belt broke, steps are
1) Remove Engine
2) Make it a new big paper weight
3) Find new Engine
I have never seen a honda engine survive breaking a timing belt. It is nice to replace the timing belt through and all the seals while you are at it, like the front main seal and camshaft seal since you are removing those parts anyways. Like Jmunk said, check spark, fuel delviery, and see if there are any codes being thrown by the computer. What happens when you try and start the car? Any sounds, lights, pieces clunking around?
Old 12-10-2002, 08:48 AM
No, I have seen dozens of D-series motors that the timing belt has borke on and only 2 have had damage to the valves. Most of the time the people luck out and nothing meets.
Old 12-10-2002, 11:18 AM
turbcivic's Avatar
We had an s200 come into work that had a bad timing and broke after running it real hard. Imagine the damage when the car was revving at 8 grand and the timing belt broke?
Old 12-10-2002, 11:48 AM
Oh man that would would hurt me just to pull the head and see the damage. Poor bastard paid big for that i bet.
Old 12-10-2002, 12:21 PM
turbcivic's Avatar
Nope, it was a pain in the ass that yelled warrenty. We got paid for only half the labor to rebuild the head and pistons. The car only had like 7500 miles on it.
Old 12-10-2002, 12:57 PM
Killa_CRX's Avatar
Killa_CRX Killa_CRX is offline
When Civics Attack!
I thought for sure the s2000 would use a timing chain instead of a belt... oh well, maybe that's just the Si and RSX?
Honda Enthusiast
Old 12-10-2002, 03:05 PM
uhh
do you see broken timing belt anywhere? i said i need to know how to replace one....mines worn out not grabbing....anyhow any Real Help would be appreciated, thanks late.
Old 12-10-2002, 06:46 PM
Hmm...well when a timing belt goes bad it strecthes and skips a tooth and breaks. I doubt that the timing belt is causing your car not to start if it's not BROKEN. How did you come to the conclusion that it's the timing belt giving you the problem ? I have heard of a case or two where the belt has jumped a tooth, but it would still run, just like crap. Before you go changing the timing belt i would make sure thats why it's not starting, but if the belt isn't broken than you have other problems. As far as me telling you how to change it i reccomend you get Helms or a Chiltons book and read up, i'll explain anything if you need it but get a book first. Oh if you want real help than i can type all night.
Old 12-10-2002, 07:31 PM
hey
well im not getting spark is why i say that... and my dizzy is fine, i had my uncle look over everything and he said it was my belt.the car turns over just no spark...
Old 12-10-2002, 08:53 PM
You should test the coil...is that turns out okay than the ignitor could be bad. Did you go to start it one day and it didn't start or did it die while driving it ?
Old 12-10-2002, 11:51 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Re: hey
That's not your timing belt. I'd get a second opinion on that. True, a broken timing belt would not allow your car to start, but spark would be the least of your problems. Trust me, that's not it. First off, check your main relay. Also, check your coil inside the dizzy, measure the resistance between the terminals to see if it's good. Also, you may want to check and see if your ECU is throwing any codes. And, how do you know it's not getting any spark? may want to double check that... There's a million things that could cause your car not to start, but in your case, I'll eat my hat if it's the T-belt.
Old 12-11-2002, 01:18 AM
hey
well actually it was a while back, my while driving my car just started slowing down and died on me, i looked over everything, and the 3 outta 4 of the plugs were filled with oil, so i cleaned it out, got new plugs, replaced my old seals, and tried it, just heard the motor turning over but no start up, thought it was the dizzy, well i got a new one used one and tryed that, nothing same exact shit, so i would assume that the t belt is the problem since the dizzy isnt giving any spark...
