Old 12-21-2007, 01:31 PM
flashlight flashlight is offline
Frothy Oil
I noticed it when I took my air filter off. It's coming from the tube that connects the air filter to the PCV hose. First of all what could be causing it to look like soda froth? And second is there someway or something to fix? This frothy mixture shoots straight into the carburator which I'm sure is not good for it.
Old 12-21-2007, 09:12 PM
TENGRAM TENGRAM is offline
Re: Frothy Oil
your PCV valve should be keeping most of the oil from traveling with the crankcase fumes into your intake airstream. if you haven't done it recently you should replace the PCV valve. also would be a good idea to make sure the PCV hose is not partially clogged. a smaller inner hose diameter will create higher velocity which will draw more oil up.
1999 geo metro LSi
1989 ford mustang gt www.my5oh.com
Old 12-22-2007, 03:10 AM
Re: Frothy Oil
Maybe 100 miles or so ago I replaced the PCV valve. I also proceeded to clean the hose out with carb cleaner and I flushed it until the fluid came out clear. Are there anymore suggestions that you have that I could try out. Thanks.
Old 12-22-2007, 07:07 PM
mtran2000 mtran2000 is offline
Re: Frothy Oil
My 95 Metro does the same thing. I have about 137,000 miles on it. Only thing that seems to help is Lucas oil stabilizer. Not a long term fix but helps until I decide if I want to spend the money on engine rebuild.
Jasper
Old 12-22-2007, 08:46 PM
Re: Frothy Oil
What is Lucas oil stabilizer and what does it do? Also what does it cost for a bottle of it?
Old 12-23-2007, 10:14 AM
Re: Frothy Oil
My Metro was going through a lot of oil. Not leaking it but going somewhere. Probably needs rings and valves. Lucas oil cut way down on consumption. You can get it at just about any auto store. You can also google lucas oil and read about it.
Not a long term fix mind you
Old 12-25-2007, 12:07 AM
RossT RossT is offline
Re: Frothy Oil
If you live in a very cold climate and your metro doesn't get warmed up enough, you will find all kinds moisture condensation in the valve cover, pcv hose and under the oil fill cap. I have 2 metros and they both do this in the winter only.
Old 12-25-2007, 06:16 PM
Re: Frothy Oil
I can't say that Idaho gets that cold.
