Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 12-21-2007, 12:06 PM
No-Tox No-Tox is offline
Problem with punch 4X4 on 2003 1500
I bought this Sub used a few months ago and everything checked out at the time. Now where the 2 high, 4 high, 4 low or Auto push button lights are not working and won't shift. It is in 2 high right now, so still driveable but the light next to the 2 high is not lit (as none of them are lit). When I push an of ther other buttons to transfer it into 4 wheel drive, nothing happens. Any quick cure before taking it into a mechanic?
Old 12-26-2007, 06:59 AM
myjunkycar myjunkycar is offline
Re: Problem with punch 4X4 on 2003 1500
I had a 2000 silverado that would not go into 4 wheel drive. Local shop told me that a servo was bad. $400. I took the switch out of the dash and looked at the soldered joints on the inside. Resoldered a couple and everything worked fine.
Old 12-26-2007, 09:38 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Welcome to AF.
You will need a transfer case/transmission capable scanner to check it out and get codes.
Post back code no.
MT
