Brake changing question
Hi all,
Getting ready to change the front rotors and pads and back pads this weekend. When I changed the brakes on the wife's BMW a while back I followed these instructions: http://m3.madrussian.net/diy_front_brake_pads.shtml Should I do the follow step for my 02 Pontiac Grand Prix GTP Coupe as well? "Apply a liberal amount of anti-squeal compound to the new pads in the area where they will contact the caliper and piston (use the old pads as a template)." and then with suggestions from this board I also bedded the new brake pads on the BMW. Do I need to do that for the Pontiac as well? I see there isn't a brake rotor/pad changing in the Tips and Maintenance forum. Is there an external documented procedure someone can recommend? Thanks, -GT |
Re: Brake changing question
Maybe the reason there is no procedure
in the Tips & Maint directory is because of the ease GM's great design of changing out the front/rear pads & rotors on 97-03 GPs. IMO, what a cake job to swap out pads & rotors on the GP! Experience wise, in my case on my 98 & 99 GPs, I found the pads with out anti-squeal compound on the piston side of the pads and installed the new ones the way I found the old ones installed. The FSM says you're supposed to burnish the rears after new ones are installed, but I didn't bother and haven't experienced any squealing noises.
mark ![]() Love my Pontiacs! '04 GP GT1 '02 Bonneville '98 GTP - 2 dr '98 GTP - 4 dr '99 GP "Flaming Tomato" GT |
Click here
Thanks.
Got everything swaped out on the front, new pad and rotors. It was pretty easy, but those bolts were freaking hard to loosen. That part wasn't fun at all. Going to do the rear pads next weekend. Thanks, -GT |
1/2 inch breaker bar is usually the ticket to get the caliper to steering knuckle bolts loose on the front. On the rear, you are pretty much limited to a 1/2 inch ratchet at most due to clearence issues and not being able to turn the wheels.
-2000 Grand Prix GTP 170,000mi (daily driver) -2000 Olds Alero 100,000mi (soon to be DD with gas at $3.45/gal) -1997 Chev K1500 4x4 115,000mi (Natalie's truck [nans_grandprix]) AF "2.0" Community Guidelines Conservative Victory 2012!!! "I'll Keep my Guns, Freedom, and Money. You can Keep the Change!" ----->>>>> Did You Know? <<<<<----- |
