Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 12-21-2007, 10:00 AM
ucshuff1 ucshuff1 is offline
Problems Starting
Everytime I crank my Jeep it takes me two or three times turning the key before it would finally crank. I took it too the dealership and they charged me $430 to replace the fuel pump. It still takes me two or three times to get it started but only after it has sat for a few hours. I was just wondering if anyone else has had this problem or if it is common or if the repair guy is jipping me.
Thanks
Old 12-23-2007, 01:33 PM
gtmud gtmud is offline
Re: Problems Starting
Well if the dealer charged you for a fuel pump and the problem is still there than I would take it back and make them fix it right at no charge to you. The only reason they should have installed a fuel pump was the lack of pressure. but if you have a bad connection in the ignition switch than the pump would not work either. Sounds like they mis diagnosed your problem.
When you cycle the key to run, does anything happen? If your dash comes up, than Iwould start by checking you ground and power to the starter. good tight and clean connections.
Old 12-23-2007, 01:34 PM
Old 01-04-2008, 07:41 AM
Aurora_Alpine's Avatar
Aurora_Alpine Aurora_Alpine is offline
Thanks
It might be the fuel regulator why don't you have it check in a shop they will check the pressure with a special gauge they have and you will find out if is good or not
92 Civic Hatch D15B Vtec
91 Sentra 1.6 DOHC
Old 01-28-2008, 09:36 PM
delacyelectric delacyelectric is offline
When was the last tune up. plugs, wires, cap rotor ect. can make a world of difference. grab your wires are they spongey. I have a 94 and when I first bought it I'd crank it for 3-4 min ( not at one time) usually I'd leave my foot on the pedal all the way to the floor. then it start. after it cool down I'd have to do it again. like your. I did a tune up and it stopped. Also is there whte smoke when it starts ? you may have a small head gasket leak. after it warms up the metal expands and the smoke goes away. but you need to push out a liquid in there. before you can get it to fire. I saw this in a friends jeep. hope it helps. get a refund for the pump.
Old 02-16-2008, 04:10 PM
dsuydam1 dsuydam1 is offline
I have a 86 cherokee chief,2.5l,i cant get it to start...I have replaced the plugs and now i dont get any spark????help...
Old 02-16-2008, 05:20 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
ucshuff1, try turning the key to the on position, and waiting for the fuel pump to turn off. Sometimes the pressure will bleed off in between starts. Try it and let us know how it works out.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
