Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 12-21-2007, 01:50 AM
blackEyeSSFly blackEyeSSFly is offline
LT1 Tear Down and Rebuild
I just picked up my LT1 and im gettin ready to start on the tear down clean and rebuild process...any tips from you pros
Cardomain http://www.cardomain.com/ride/2143750
Success is to be measured not so much by the position that one has reached in life as by the obstacles which he has overcome
Old 12-21-2007, 07:11 AM
96capricemgr 96capricemgr is offline
Re: LT1 Tear Down and Rebuild
Why do you want to rebuild it???
What is planned to be machined in this rebuild?
What do you want out of the motor afterwards?
Most shops can not match the quality of GM's bore and hone or valvejob, don't be too quick to let some hack mess them up.
The factory rotating assembly is rather good too.
My motor is making 470-520hp depending who you ask and what rating correction they apply, the bottomend is completely untouched except for a metal sleeved oil pump driveshaft and a higher pressure relief spring in the stock oil pump. Never even looked at the bearings of slide a piston out of a bore.
96 Caprice Medium Garnet Red
11.56 at 115.9mph naturally aspirated
94 Caprice wagon, rotted out POS
