NO Charging
Installed new battery, altenator and fusible link all grounds cleaned. Still will not charge. Any ideas where to go from here?? qyouq
Re: NO Charging
A voltage drop test across the alternator and battery+ terminal may reveal high resistence. This is where I'd start, assuming your alternator, battery and grounds are good.
-MechanicMatt
1996 Caprice 9c1 - Daily Driven Project Car 1993 Geo Metro - Accident 1991 Caprice 9c1 - Destroyed
Re: NO Charging
Schucks will test your alternator for free, if you take it in. Chances are, the regulator is toast.
Re: NO Charging
Don't know what your car is. I have a 89 metro and there is a medium gage charging wire w/ connector that plugs into the bottom front of the fuse box under the hood. Mine is located right behind the washer fluid tank. I pulled the tank off to get a good grip on the connector and scraped the inside of the connector and bent the edges so it made better contact. Took about 5 minutes. Hope this helps. Good luck.
