Old 12-20-2007, 03:20 PM
safari sufferer safari sufferer is offline
safari transmission
I've been told I need a new transmission...no 2nd and 4th gears, no reverse, etc.
Whats better, a reconditioned tranny or rebuild my existing tranny? Have had both offers...$2200 - $2300.
Is this a common problem...2001 Safari, 4.3, 6 cylinder, rear wheel drive, 220k odometer.
Thanks
Old 12-20-2007, 06:14 PM
old_master's Avatar
Advisor/Moderator
Re: safari transmission
Does the Service Engine Soon light work? If so, is it on when the engine is running? If it's on, what codes are stored? It might be an inoperative solenoid in the transmission.
Old 12-20-2007, 07:14 PM
yes the light is working.
the light wasn't on when it was running earlier, but i will check out and get back to you. thanks!
if it is in the transmission, is it a big job to fix?
Old 12-20-2007, 08:21 PM
brcidd's Avatar
brcidd brcidd is offline
Last time I needed a tranny I did an internet search- found one with 86k on it for $350 at a boneyard- it was a piece of cake to replace- plug and play- took only an afternoon- was pulling my trailer the next day...so I highly recommend used parts for the money- you can't beat it- especially if you supply your own labor....
I just looked yours up-- saw a bunch under 100k- and at about $450 .....all wheel drive would be harder to replace
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 12-20-2007, 09:54 PM
Interesting! Where did you see these trannies?
I have climbed under the van and noticed how the engiine and transmission is exposed and accessible.
Thanks
Old 12-23-2007, 05:46 PM
Blue Bowtie's Avatar
Registered Offender
All you need is a reaction sun shell - $180 total repair cost:
http://www.wwdsltd.com/4L60/4L60ERepairs.html
Old 01-02-2008, 12:13 AM
kidneystone kidneystone is offline
I posted this in another thread but it pertains to you also..
Primary Valve body needs to be drilled and honed to avoid this happening
again.. There was a service bulletin on this tranny that not many
tranny shops look into and if not done the tranny will build up
serious line pressure and do this all over again. The computer detects
a build up of line pressure do to the orifice is to small for the needle
to pass the correct line pressure. The computer will see this as a problem
and build more line pressure to avoid the slip which in turns burns the clutch.
This problem is always the second gear clutch failing. My bet before this
happened you probably noticed a harder shift to second.
This is a very common problem that GM decided was not enough for a recall.. (stupid)
After the tranny is rebuilt correctly you shouldn't have a problem again. Just a shame
that GM waited till 2003 to recognise there was a problem with the 4l60e
Old 01-02-2008, 10:42 AM
Thanks for that.
Come to think of it, it did shift strangely from first to second for a few weeks before.
So does it sound like a tranny rebuild to you?
Greg
Old 01-06-2008, 08:39 PM
Originally Posted by safari sufferer
Thanks for that.
Greg
You are welcome. The bands most likely are worn severly, so yes a rebuild
is due.
Old 01-08-2008, 06:51 AM
Registered Offender
is due.
FWIW, there is only ONE band in a 4L60.
Old 01-08-2008, 09:40 AM
You are correct, my brain is not funtioning.
Old 01-08-2008, 09:04 PM
Registered Offender
That's O.K. January 8th is the ONLY day my brain IS functioning right, and then only with adequate caffeine, and then only in Leap Years...
I'm still betting he's going to find a problem at the hub of the reaction sun shell once the trans is torn down.
Old 01-09-2008, 10:44 AM
More than likely. Heck when that line pressure goes up and puts all
that extra strain it tears the hell out of stuff.
