Go Back   Automotive Forums Car Chat > Pontiac > Sunbird/J2000/2000 Sunbird
Old 12-20-2007, 01:04 PM
zacmang zacmang is offline
91 sunbird 4cyl..died wont start help!!!
my sunbird was started runnen rough as soon as it started gettn cooler out. then one day i started it on a cold morning and didnt let it warm up long enuff and it died in reverse...i havent been able to get it to start for a week. ive tried jumping it but it dont work. i let it sit for awhile and it gets one good crank but wont fire..after u try to crank it over more then once it wont even turn over....any tips???
also is there a carb or since its fuel injected means no carb/choke?
Old 01-25-2008, 06:06 PM
anomaly_va_1976 anomaly_va_1976 is offline
Re: 91 sunbird 4cyl..died wont start help!!!
No Carb or choke on FI..... Two possibilities.... If it is an automatic, the Torque Convertor Clutch solenoid could be stuck.... Also the 2.0 OHC has a timing belt... check to make sure it has not jumped time or broken altogether. Also check fuel pressure at the fuel injector rail ( same type of valve as a tire valve stem) should be around 40-45, any less and the injectors will not open....
Don't Worry What Others Think -
They Don't Do It That Often!
James Collier < [email protected] >
1992 Chevrolet Cavalier Z24 Convertible (3.1, 5-sp) *** FOR SALE -- SEE CAVALIER CLASSIFIEDS ON AUTOMOTIVE FORUMS.COM***
1993 Chevrolet Beretta (3.1, 3-sp auto)
1995 Mercury Marquis (Taxicab, i.e., breadwinner)
