Go Back   Automotive Forums Car Chat > Chevrolet > Express | G Van
Old 12-20-2007, 08:03 AM
jag7720 jag7720 is offline
front suspension
Is there any way to add an additional mount to the front suspension so I can add a second set of shocks?
I just put new shocks on the van and I am still hitting the rubber bump stops when I go over small dips in the road.
Or got the shocks that are for that van. Is there a better way to stop this from happening?
It is an 87 G20 Diesel - Beauville
Old 12-20-2007, 08:35 AM
denisond3 denisond3 is offline
Re: front suspension
We have a G20 with the 350, but I havent noticed it bottoming. On ours I dont think the shocks would stop it from bottoming - unless they are a type you could pump up with air pressure. I would wonder if you had a cracked coil spring in front.
Old 12-20-2007, 09:20 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Springs is what holds the front end up.
They may be getting weak.
Check the ride height.
MORE SHOCKS WILL NOT HELP IT.
Shocks only take the bump out of the bump.
MT
MT
