Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 12-20-2007, 01:04 AM
DAVE7695 DAVE7695 is offline
1994 toyota 4 runner rear heater
the rear heater on my 4 runner is no longer working not hot air at all only cold.. Front is working fine
Old 12-22-2007, 07:51 PM
OzzyO's Avatar
OzzyO OzzyO is offline
Send a message via MSN to OzzyO Send a message via Yahoo to OzzyO
Re: 1994 toyota 4 runner rear heater
Check under your 4runner and make sure there is coolant in the lines going to your back heater. This is also connected to your radiator so check to see if your coolant is down in your radiator. No coolant and you could lose your engine .
Good Luck
OzzyO
Old 01-13-2008, 01:04 AM
4Wheel's Avatar
4Wheel 4Wheel is offline
AF - Advisor
Check your coolant levels and burp the system if it was low.
The coolant for the rear heater is tapped off the highest point of the system.
