Old 12-20-2007, 12:03 AM
adigiovanni adigiovanni is offline
98 Taurus - transmission problem?
When I come to a stop the car goes into netral even though it's still in drive. I'll drop it into L2 start to drive and put it back into drive and everything is fine until I have to stop again. In which case I repeat the process. Now I didn't have this problem until I had to have the steering colum changed out.
What is going on and about how much am I looking at to get it fixed?
Old 12-20-2007, 12:27 PM
shorod's Avatar
shorod shorod is online now
SHO No Mo
Re: 98 Taurus - transmission problem?
I'm going to assume that your Taurus has the column shift. I'd suggest you take it back to where you had the column changed out, maybe they didn't get the shift linkage adjusted appropriately. When you shift to "2" does the transmission stay in 2nd gear, or does it seem to function normally? Do neutral, reverse and park seem to line up fine according to the gear indicator?
-Rod
Old 12-21-2007, 12:46 AM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
This has nothing to do with the shifter.
This is typical AX4S actuator piston warpage->failure.
It basically requires rebuilding the transmission.
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
