Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 12-19-2007, 03:19 PM
cbmcleaning cbmcleaning is offline
Warning Lights when start 2003 Impala
Just recently...my BRAKE FLUID LOW light...and TRACTION OFF light have come on when I start car in the morning.
It is usually ok...starting up...then...when I pull out into the street and give it some gas.....THESE LIGHTS come on the dash....
I just had engine oil changed..and they check the fluid levels in all resevors and ALL fluids...including BRAKE fluid was fine.....?
They eventually go off after driving it for a few minutes...
Any ideas?
Thanks
MikeV
Old 12-19-2007, 04:29 PM
SpinnerCee's Avatar
SpinnerCee SpinnerCee is offline
Re: Warning Lights when start 2003 Impala
As long as the indicator goes off quickly as you use the brakes and never happens during or shortly after a drive, suspect the colder weather, and the possibility that there may be moisture (or even air) in the brake fluid (has the brake system ever been flushed/refilled/bled?).
* one more thing... as the brake pads (or rotors) wear, the fluid level will get lower. Maybe your rotors and pads need some attention.
.:: DigitalMIX by djSpinnerCee ::.
Old 12-19-2007, 04:32 PM
Yes I was going to mention that...I noticed it started when the weather turned colder...
Ok...looks like you are right....THANKS
MikeV
