225/60/16 tires on a 1999 Grand Am
The original tires on my GA are 225/50/16
Does anyone knows if a tire 225/60/16 would be ok for this car. I'm worried about rubbing of the tire inside the wheel well. Pease suggestions Thank You Weber |
Re: 225/60/16 tires on a 1999 Grand Am
I really doubt you will have an issue with the taller tire since you are only increasing them by 10mm. Although if you are purchasing a set stick with the 50 series.
Rear clearance isn't an issue, but they might rub in the front if turning the wheel all the way in either direction, plus check the amount of room between the tire and the strut. I know some of them are very close.
Rusting out Honda Civic $900 Fart cannon muffler: $300 Assorted stickers advertising products you'll never own: $50 Having your @ss handed to you by a brick shaped suv: Priceless. Yup, I own the suv. |
The 225/60/16 is actually much larger.
To figure tire diameter in inches (if you have Excel) paste "=(((B2/10)/2.54)*(C2/100))*2+D2" into cell A1. I think that's right, I used to be great at math, but after not doing any for so long, my brain actually hurt while tryting to think of that. B2 is section width (the first number of the size) C2 is the sidewall (second number of the size) D2 is the rim size. The metric tire sizes are plain dumb if you ask me. The 60 series is not 10mm larger than a 50 series. The first number is the section width in milimeters. The second number is the sidewall height (as a percentage of the width). The third, of course is the rim size. 60 series is 26.629" diameter 50 series is 24.858" diameter
'04 Cavalier coupe M/T 2.2 Ecotec Supercharged 14 PSI boost, charge air cooler, 42# injectors Tuned with HP Tuners Poly engine/trans/control arm bushings Self built and self programmed progressive methanol injection system |
