Old 12-19-2007, 11:28 AM
rjeffery rjeffery is offline
Bleed Brakes
If I want to replace my brake fluid (as part of regular maint), what is the best way to bleed they system without having to have the ABS unit bled with a scan tool? Can I just bleed each line at the caliper while keeping the reservoir full, or is having the ABS unit bled unavoidable?
02 1500.
Thanks in advance.
2002 1500 Ext. Cab 4.8L 2wd.
K&N FIPK, Cat Back Exhaust, Rancho RSX Shocks, Silverstar Headlights High & Low, Infinity Reference Door Speakers & 10" Dual Voice Coil Sub. 265/75/16 BFG AT/KO's, Spray-In Bed Liner, Hella FF75 Fog Lights, Hella FF75 Driving Lights.
Old 12-19-2007, 02:42 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Bleed Brakes
As long as you keep the fluid full, you shouldn't need to activate the ABS solenoids, you just won't be replacing the fluid in the ABS circuit. I would suck as much old fluid out of the reservoir and replace with new before you begin.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 12-19-2007, 11:29 PM
Re: Bleed Brakes
Sounds good, thanks. I just don't want to have to mess with having someone bleed the ABS.
Old 12-20-2007, 03:27 AM
G.A.S. G.A.S. is offline
Re: Bleed Brakes
a turkey baster works well for removing the fluid from the master
