Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 12-19-2007, 04:59 AM
glewis glewis is offline
Wiper ciruit board
Hello
I have a 94 burb and the intermitent wipers have gone crazy. They work when they want to whether it is raining or not.
I bought a new wiper circuit board, but do not know where it is located.
Can anybody help with the location of this circuit board?
Old 12-19-2007, 07:36 AM
Old Dave Old Dave is offline
Re: Wiper ciruit board
If yours is like my 97 Suburban, it's inside the wiper motor housing under the hood. Remove the 4 torx screws and unplug the connector to remove the board. Look for cracked/broken solder joints where the connector is mounted on the board. These were notorious for having bad solder joints. You can probably touch these up if you have a soldering iron and resin core solder and fix your problem without replacing the board. That's what I did on mine.
Good luck...
1970 GMC 2WD shortbed fleetside
1984 Olds Delta 88 (won't die)
1997 GMC Suburban K1500 W/5.7L Vortec
2000 Dodge Ram 1500 4WD Shortbed Ext. cab
1998 Chevy K2500 W/5.7L Vortec
2002 Harley Custom Chopper
Wife is a late 1951
Old 12-19-2007, 10:19 AM
Christophe Salvain Christophe Salvain is offline
Easy to fix. I did it. It works.
Check these links .
http://www.automotiveforums.com/vbul...d.php?t=512424
Indeed you can buy the circuit. However the problem is most of the time with broken solder connection on that circuit. Remove the circuit, and carefully solder again all connections specially those leading to the wire connector, and you can be back with normal wipers for 0$.
take a view at this (90-96 model)
www.avigex.ca/xport/wiper1.jpg
www.avigex.ca/xport/wiper2.jpg
www.avigex.ca/xport/wipermotorphoto1.jpg
www.avigex.ca/xport/wipermotorphoto3.jpg
www.avigex.ca/xport/wipermotorphoto8.jpg
www.avigex.ca/xport/wipermotorphoto9.jpg
www.avigex.ca/xport/wipersyndrome.pdf
Christophe Salvaing
Old 12-21-2007, 06:04 AM
Thanks to all who supplied information.
1994 Suburban - 199,987 miles
1995 Sonoma S15 - 200,158 miles
1996 Buick Century - 127,229 miles
2006 Caddy Escalade - 32000 miles ( wife's )
