anyone kno how to replace a fuel pump
fuel pump went out on my 91 civic hatch and i wanna kno how to replace it...... plzz help thats my daily driver and things been hard with out a car............ THANX!!!
Re: anyone kno how to replace a fuel pump
May check the Main Relay first. Most of the time that's what it is. It's only about 40 dollars compared to the 160ish for the fuel pump. Listen for a click under the dash when you turn the key on, behind the change holder.
you have to drop the tank to replace the pump.
AF Bay Area Crew ![]() RIP Melt 2008 Mitsubishi Lancer Evolution GSR 2007 Toyota Prius ![]() ![]() I <3 and miss my 4g
oi, check under the rear seat, some models were equipped w/ an access panel, if there isn't one, you can always "make" one.. it's a hell of a sight easier than dropping the tank and breaking one of the studs that are moulded to the body.
I was gonna check the sock on my fuel pump last week and thought it was like the later model cars that let you get to it through the access panel....not true. Access panel lets you get to the sending unit, not the pump. Needless to say, I haven't checked the sock on my fuel pump(getting some random sputtering, managed to get some water in the fuel somewhere) and don't plan to just yet. Too damn cold to be out dropping a gas tank to check a little filter.
Tony 91 Civic Sedan DX - Stock 287k Miles |
just about every honda sicne like 85 shoudlve had an access hatch/ cover of some kind to get to the fuel pump. i dont know why is 91 would be so magical as to not even have one. ive got a dx and its got one. had a 90 std and it hado ne.
06 cbr 600 f4i 91 civic hatchback. 96 nissan pathfinder |
there is an access to the fuel gauge sending unit, but not the pump.
Yep. I thought it was to the fuel pump also, then I took it out and realized it was only the sending unit.
well that's ghey... speaking of sending units tho, will the factory gauge work w/ a GM-style (0-90 ohm) sending unit?
and OP, you now have two options.. you can either widen out that hole, and properly prep the opening before re-covering it, or you can drop the tank, and probably have to get someone to weld a new stud up to the body. |
