Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 12-18-2007, 08:19 PM
mitch_houser mitch_houser is offline
Plug it in it's getting cold
Just thinking out loud sure feels good to crank up the beast on these 26 degree mornings and have nice warm air at crank.Thanks Dodge for putting a block heater on my truck.
Old 12-19-2007, 11:42 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: Plug it in it's getting cold
Mine doesn't make the heater real warm but the motor comes up to temperature quicker.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 12-20-2007, 06:10 PM
WHATDIDYOUBREAKNOW WHATDIDYOUBREAKNOW is offline
getting?
it's been!!!!
Old 12-20-2007, 07:29 PM
BigLou101 BigLou101 is offline
ive got a question my engine builds heat but doesnt blow warm air through the vent would this be a heater core issue or a resistor malfunction
Old 12-20-2007, 08:36 PM
AF - Advisor
My problem was the thermostat sticking open and not letting the coolant heat up past warm...the temperature gauge only showed 1/4 after driving a while.
After replacing the thermostat with the correct/genuine Cummins thermostat with the spring loaded washer valve for the water pump bypass...determined with the actual engine number on the ID tag mounted on the timing gear case...it comes up to 190* and heater gets very hot.
Old 12-30-2007, 11:23 AM
the truck it self heats up no problem its just the heater doesnt blow warm air unless on the lowest setting
Old 01-05-2008, 07:30 PM
AF - Advisor
The heater core can get kinda clogged if stop leak or old coolant is in the system.
There's a heater blend door (that closes for max heat) that can stick open and allow cold outside air to mix with your good heated air.
Old 03-04-2008, 03:44 PM
moparman1994's Avatar
moparman1994 moparman1994 is offline
my cummns does alot better when I plug it up especially being in North Dakota in negative temps sometimes
'05 dodge cummins 2500 smarty, ss nerf bars, stacks, fire & ice taillight bar, auto meter gauges on a- pillar
