Old 12-18-2007, 08:03 PM
thisismylife thisismylife is offline
some times wont start
First thanks for reading my post
I have a 1987 Cherokee pioneer with the 4.0 inline 6 when I start my jeep it is low cranking when I go somewhere some time it will not do anything the lights all work gages work but it will not do anything I hear a clicking under the hood is it the starter or the starter cyclones thanks
Old 12-18-2007, 08:12 PM
spookie5996 spookie5996 is offline
Re: some times wont start
most likely it is your starter. the next time it doesnt start try hitting it with something hard like a wrench. sometimes that works to get it started.
Old 12-19-2007, 12:19 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Slow cranking to me indicates low voltage. I'd consider testing and possibly replacing the battery.
Also, check the positive battery cable; I've seen vehicles get corrosion on the inside of the cable, which caused all sorts of issues
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 12-19-2007, 12:23 PM
RaeRae1's Avatar
RaeRae1 RaeRae1 is offline
Send a message via AIM to RaeRae1
+1 on the battery issue. Double check the battery connections, clean them up if they are corroded. If you are not getting a good connection it can make click/crackle noise. Check that first then let us know.
Blessed are the cracked ones, for they are the ones that let in the light.
Originally Posted by 72chevelleOhio
Your cheer-mobile needs a flat tire.
Old 12-19-2007, 05:16 PM
dave92cherokee's Avatar
dave92cherokee dave92cherokee is offline
I'm currently experiencing the same problem randomly. On mine the negative battery cable connection at the battery is a little loose and sometimes will vibrate around to where it's loose, all I do is turn it back so it's tight again and it fires right up. So sounds like the same problem I'm having, best thing to do is get a new battery unless the one you have is less than a year old, then get a marine battery terminal for it (the brass ones) as they prevent corrosion unlike the typical lead ones. Then get either new cables with a ring terminal on the end or get a ring terminal to connect to the wires and then onto the terminal, make sure to wrap them in electrical tape real good to prevent any corrosion there as well.
Old 12-20-2007, 08:03 PM
ok i have tried everything that's been said and this morning i had to beat the starter with a hammer and then it stares up so i think the starter is about out thanks
Old 12-21-2007, 08:20 AM
AlohaBra's Avatar
AlohaBra AlohaBra is offline
That would indicate the starter solenoid is sticking.
Old 12-23-2007, 03:03 PM
Ok I went a got a starter last night and put it in and it work grate now so thanks to every one
