Old 12-18-2007, 06:31 PM
beatboxn420 beatboxn420 is offline
Once Again..
Newb need help:
HK12X2 Subs, 12inchers. 1500 RMS. 2 Ohm.
-Already have them.
Needing AMP:
MA Audio has HK2000D Monoblock. Now mono means I can only run one sub off of it? Or what? Its 1800RMS @ 1 Ohm.
Can I run both 12's off of one, having 1800 push to each sub? Or since its Mono, i can only run one?
Need Help Badly
-Tj
Warning: Objects In Mirror No Longer Matter
Old 12-18-2007, 07:52 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: Once Again..
mono just means it only has one channel, you can run as many speakers as you like on it. The only thing is, you have to watch the total impedance. In your case, you can wire those 2 subs in parallel to make a 1 ohm load that the amp is most powerful at. As for power, it is divided equally among the speakers - so 2 speakers will see 900 watts each.
Old 12-19-2007, 03:05 PM
Re: Once Again..
How about the MA Audio HK802SX amp. Its rated 4400 watts @ 1 ohm when bridged. So I can run my two HK12's to it, when wired parrell, and get 2200 watts to each sub?
-Tj
Old 12-19-2007, 05:41 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: Once Again..
i would be putting money into electrical before you even think about buying an amp. You wont be able to run over 1krms on a stock electrical... You're stupid if you think you can run this so called "4400wrms' off a stock altenator.
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 12-19-2007, 06:10 PM
Audio Guy
Re: Once Again..
I think MA audio is overrated ...... but then I'm not a basshead either.
Old 12-19-2007, 06:25 PM
pre98zetec's Avatar
Re: Once Again..
VERY overrated
-Josh-
Old 12-19-2007, 10:29 PM
PlayStation3 PlayStation3 is offline
Re: Once Again..
they are like hifionics there top line puts out rated power but nothing else. lol
Old 12-20-2007, 02:59 PM
pre98zetec's Avatar
Re: Once Again..
not to mention most MA amps are rated at like 16v. So unless you have a serious alt or a dedicated alt for car audio you will never see the rated power... even with perfect voltage you wont see rated power.
-Josh-
Old 12-20-2007, 08:20 PM
Audio Guy
Re: Once Again..
ok, that's what it was ... they are rated at a rediculous voltage
Old 12-21-2007, 03:09 AM
pimprolla112's Avatar
pimprolla112 pimprolla112 is offline
Send a message via AIM to pimprolla112 Send a message via MSN to pimprolla112
Re: Once Again..
I thought it was 18v. I like it when amps are actually rated at 12v, but thats even hard to find today.
I wouldnt trust those subs with 1000 watts to a pair let alone 3k. Look into an Autotek mm4000.1d, if you want real wattage.
Cant remember who posted it but if you see it give yourself credit
Don't ever look at cars as just imports or domestics. Just because a car is made in a certain country doesn't mean that it is anything like another car from that country. An example of this is Mitsubishi reliability, just because they are Japanese doesn't mean that they are as reliable as a Honda or Toyota.
Cardomain
Old 12-21-2007, 07:26 PM
Audio Guy
Re: Once Again..
the new CEA ratings specify 14.4 volts for power input. It's ok as long as everyone agrees to the standards.
here is a good article by Andy Wehmeyer
http://www.jbl.com/car/product_suppo...IA_CEA2006.pdf
Old 01-03-2008, 01:33 PM
Re: Once Again..
OK, well. I just purchased a HK802SX (4400 RMS @ 17v). Im getting an Optima Yellow Top.. but I need a capacitor.. what type.. as in Farads, would be recomended..
-Tj
Old 01-03-2008, 03:04 PM
pre98zetec's Avatar
Re: Once Again..
for the last TIME. what do you not understand about you CAN'T run over 1krms off a stock altenator, You can put a trunk full of batterys and 50 caps your still not going to be able to run it!!!!!!!
Have fun replacing that amp when you blow it, first drop below 11v that amp pops.
Whats recommend is stop buying junk (i know I sound like an ass here) but MA audio anything is pure crap (over rated subs, over rated amps, over rated everything). You coulda bought a decent setup AND a charging system for the money you dropped on those two items
You're NEVER going to get 4400rms from that amp, 3000wrms clean power if your lucky (@ 17V+). Oh yea, notice how its at 17v? You do know cars electrical is 12-14v? with that amp your gonna drop well below 11v, probably making 1000rms IF your lucky. Not to mention probably blow the amp due to poor charging system.
-Josh-
Old 01-03-2008, 05:49 PM
Audio Guy
Re: Once Again..
I agree, you're trying to buy equipment that is designed for high level SPL comps. You will also need the oversized electrical system to go with it.
