Old 12-18-2007, 04:48 PM
dogkatcher's Avatar
dogkatcher dogkatcher is offline
how to loosen harmonic balancer bolt ? (crankshaft pulley)
90 cherokee laredo
i tried to loosen the bolt on crankshaft pulley .. it just spun the pulley, so I spun it back to where I thought it originally was ... did I screw anything up by it turning ? (with engine off of course) ... how is that threaded?? standard or reverse
I also heard a noise in the crankshaft as if it was going to turn the engine over.. glad I disconnected the battery
how do you get that bolt out? i got a removal kit & a new pulley, the one in there has decayed rubber sticking out around the edges .. Im putting a new water pump in so I need to get this done while im in there .. help!
how much do shops usually charge to do this? in case I give up on it
Old 12-19-2007, 12:14 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: how to loosen harmonic balancer bolt ? (crankshaft pulley)
There are several ways to put some friction on the harmonic balancer to keep it from turning, including pry bars, getting a friend to hold it, using the serpentine belt or any combination of those. Good luck with it, with some perseverence (and caution if using the prybar) it'll come off.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 12-20-2007, 06:04 PM
dogkatcher's Avatar
well, we got it changed today. One person holding the belt then other person used an impact & bolt came right off. was a pretty easy install.
