Old 12-18-2007, 02:56 PM
Blownpiston Blownpiston is offline
Unhappy Heater Core 2.3--1993 GA.
Searched archives, and read all posts on forum on this subject. i cannot reach or get to the heater hose clamps from above. Up on jackstands now, seems to be some big flat bar, bolted accross frame, in the way. Cant get even a good sight line on the hoses where they go into firewall. If i removed this bar, seems like an arm still wouldnt fit up in there? What is the trick here, what am i missing, or not removing? all i wanna do is remove the heater hoses, then remove the core. i tried autozone link, but goobledeegook to me? Could anyone who has done this before, please give me some pointers. Im kinda frustrated right now. Thanks people. How you get up in there?
Old 12-18-2007, 03:55 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: Heater Core 2.3--1993 GA.
I usualy can reach them from above laying on top'o the engine.
If you have it up off the floor 18-24inches that might be enough to reach around the transaxle mount, though, you can remove the rear trans strut mount for better access.
1999 Grand Am SS 3.4 OHV
Old 12-18-2007, 09:18 PM
skibum1111 skibum1111 is offline
Send a message via AIM to skibum1111 Send a message via Yahoo to skibum1111
I took the clamps off mine from above, then removed the hoses from underneath the car. The only reason I did it that way was I couldn't get enough leverage on the hose from above. Made one huge mess of the driveway as well, the heater core, even though it's leaking, holds almost 1/2 gallon of cooant.
Rusting out Honda Civic $900
Fart cannon muffler: $300
Assorted stickers advertising products you'll never own: $50
Having your @ss handed to you by a brick shaped suv: Priceless.
Yup, I own the suv.
Old 12-18-2007, 11:34 PM
Nothing like a antifreeze bath when doing this from under the car.
Old 12-19-2007, 06:31 PM
Thats why I removed them from above. I was still covered in gunk that night, but at least the mosquitos didn't like the smell of me.
Yup, I own the suv.
Old 12-20-2007, 04:00 PM
J-Ri's Avatar
J-Ri J-Ri is offline
I remember those days, I'm spoiled now, having a hoist in every bay
You may need a set of long-handled needle nose pliers (straight, 22.5, 45, and 90 degrees) to get past everything (assuming factory spring-clamps).
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
