Old 12-18-2007, 11:10 AM
pea3366 pea3366 is offline
Unhappy bypassing air on 97 grand am
have a 97 grand am with a 4cyl. how can i bypass the air or can i? need help ASAP please!!!
Old 12-18-2007, 11:30 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: bypassing air on 97 grand am
There is neither a factory belt listed w/o air, nor an aftermarket a/c compressor bypass pulley listed for your car/engine combo. Looking at the belt routing schematic, is is not possible to just bypass the compressor either, so it looks like you're SOL, sorry for the bad news.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 12-18-2007, 09:22 PM
skibum1111 skibum1111 is offline
Send a message via AIM to skibum1111 Send a message via Yahoo to skibum1111
You can try measuring the distance around the pulleys with a piece of string bypassing the compressor. This will also allow you to see if the compressor needs to be removed to avoid the belt hitting the pulley. Go to the parts store with the measurement in millimeters, plus the width of the belt, they should be able to look one up for you. Good luck.
Rusting out Honda Civic $900
Fart cannon muffler: $300
Assorted stickers advertising products you'll never own: $50
Having your @ss handed to you by a brick shaped suv: Priceless.
Yup, I own the suv.
Old 12-19-2007, 11:36 AM
richtazz's Avatar
I believe this is not valid advice. You may not be able to just bypass the AC pulley on this vehicle due to the way it is routed. Unless you know for sure that this can be done, please don't state it as fact.
Old 12-19-2007, 03:07 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Is the compressor locked up or is the pulley locked up? If it's just the compressor, unplug the clutch and use the factory belt size. Richtazz may be right about it not being possible to bypass it. I couldn't find a diagram online, sounds like he has one.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 12-19-2007, 06:28 PM
Reread my post. The string gives you the information you need, including if it will hit the pulley. And I have done it before, just not with a quad.
Yup, I own the suv.
Old 12-20-2007, 04:29 PM
J-Ri's Avatar
Looking at a diagram at work today (the photo turned into lineart style diagram), the belt will hit the stock tensioner pulley if not routed around the A/C compressor. You may be able to find a smaller pulley that will allow it to work.
