Old 12-18-2007, 09:09 AM
mohms's Avatar
mohms mohms is offline
Rear Hard Brake Lines - Size?
Anyone know the diameter of the rear steel brakelines out of the drum? It is a 91 HB. Mine are rusted and squirting! Figured I would ask here first before I question the geniuses at autozone.
I am a Tuner n00b
"Sig removed. Unauthorized advertising is not permitted"
Old 12-18-2007, 01:38 PM
mohms's Avatar
Re: Rear Hard Brake Lines - Size?
ok... i am guessing they are 3/16".
Anyone know what type of flare? "Double" or "Bubble"?
Once again i am guessing, and hoping double.
I am a Tuner n00b
Old 12-18-2007, 03:28 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
If mine still had drums I would go check for you, but I don't have a clue...can't even recall a steel line coming out of the drum. Got any local junk yards that might have it? Probably be easier to do it that way rather than making your own.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 12-18-2007, 04:34 PM
inafogg inafogg is offline
hello yes 3/16 you'll be able to get in differant lengths at auto parts shop
Old 12-19-2007, 09:06 AM
mohms's Avatar
Yep, 3/16" metric (kind of an oxymoron) is the correct size. I put a new brake line on the rear and a new caliper in the front last night.
One funny thing though, I got 2 brake line sticks at autozone, and one at murray's. (Autozone didn't have a 6" like I thought I needed. Ended up using the 12" anyways). The flare nut size is different between the stores. And of course I bought the wrong line wrench for the brake line I used! Murray's lines use a 11mm wrench, and Autozone a 10mm.
I am a Tuner n00b
Old 12-19-2007, 01:26 PM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
you don't need a flare nut wrench to tighten the lines, only to remove them after they've been installed.... brake lines tend to "work harden" after having been used for years, from vibration and such, and they "stick" in the threads, hence the reason for a wrench that makes as much contact on the "nut" as possible.
if you ever find yourself short the flare wrench that you need, find a cheap wrench at a parts store and cut a section out of it w/ a hacksaw that will just fit over your line, it will work fine, and be cheaper than a "special tool" which most parts stores consider a flare wrench to be... another alternative is to use a craftsman wrench, b/c after you're done, you can take it back, and they'll replace it w/ a new uncut one, and won't ask any questions about how it got "broken"
Old 12-19-2007, 01:48 PM
mohms's Avatar
In addition to what Dr0pZ0n3 said, if you are in a pinch and dont want to cut a wrench, but have some rust buster, use that. I didn't have a line wrench and the nut was really, really rusty. I sprayed the nut with "Power Lube" rust eater, let it sit for a while, and sprayed it again. That stuff works great! The nut came out fairly easy with a good wack to the wrench to break it loose.
And oh yeah, you can always cut the old line, and use the box end of your wrench.
I am a Tuner n00b
Old 12-19-2007, 06:42 PM
Tony's Avatar
TLD Member #1
Ummm...why not just put a regular open end wrench on it and pop it...not just apply constant pressure on it, just one good pop and it will usually come right off. Ofcourse a pair of Vise-grips works well too if you get a good grab on it. Just don't ever put constant pressure on it. I don't own any line wrenchs, and don't ever really plan to get any(not any time soon atleast) I just haven't found a reason to spend the money on a special tool that I don't absolutely HAVE to have.
Tony
Old 12-19-2007, 07:26 PM
mohms's Avatar
Ahhh... what a great life lesson. My Dad taught me this long long ago... If the nut/bolt knows you are coming it will be there to stay. If you suprise the hell out of it, it's out of there!
I am a Tuner n00b
Old 12-20-2007, 01:29 AM
If the nut/bolt knows you are coming it will be there to stay. If you suprise the hell out of it, it's out of there!<(---- rofl... seriously.. rofl.
Yeah, all those things work, but I still like the looks I get when I go back to sears to replace a wrench that I cut the end out of w/ a hacksaw... man, it's so obvious when you do it too... and they aren't allowed to refuse the return... lmao
WB tony, what happened to you the last week or so?
Old 12-20-2007, 02:12 AM
Tony's Avatar
TLD Member #1
Lost my net for a little while, and just been busy lately. Working all the time.
Tony
Old 12-20-2007, 04:14 AM
same. work. blah.
