Go Back   Automotive Forums Car Chat > Oldsmobile > Ninety Eight
Old 12-18-2007, 05:09 AM
Drewet88 Drewet88 is offline
Post Recall!!???
I was bored going to partsamerica.com and found out theres recalls about our cars. I didnt know and I dont know who knows so I'm going to post them in case anyone doesn't know. By the way, do I just go to a dealer for these I'm assuming they are free. O and would I have to go to the Buick Dealership since there is no Oldsmobile dealership?
File Date 6/24/1987
Mfr. Involved
GENERAL MOTORS CORP.
NHTSA Campaign #
87V093000
Mfr. Campaign #
Component Affected SERVICE BRAKES, HYDRAULIC:ANTILOCK
# Vehicles Affected
6004
Defect
THE ANTI LOCK BRAKE SYSTEM (ABS) PRESSURE/WARNING SWITCH MAY EXHIBIT BRAKE FLUID SEEPAGE WHICH EVENTUALLY CAN LEAD TO LOSS OF THE BRAKE SYSTEM HYDRAULIC PUMP MOTOR. ADDITIONALLY, THE HYDRAULIC PUMP MOTOR AND ABS ELECTRICAL RELAYS MAY HAVE BEEN EXPOSED TO WATER CONTAMINATION DURING VEHICLE ASSEMBLY. THIS CONDITION CAN CAUSE LOSS OF THE HYDRAULIC PUMP MOTOR AND/OR LOSS OF THE ABS FUNCTION.
Consequence
LOSS OF THE HYDRAULIC PUMP MOTOR WOULD RESULT IN A TOTALLOSS OF REAR BRAKES AS WELL AS POWER ASSIST TO THE FRONT BRAKES. THE RED BRAKEWARNING LIGHT WOULD ILLUMINATE AND STAY ON. IF THIS WARNING IS NOT HEEDED, ALOSS OF REAR BRAKES AT A TIME WHEN MINIMUM STOPPING DISTANCE IS REQUIRED COULDRESULT IN A VEHICLE CRASH. AN INOPERATIVE ABS ELECTRICAL RELAY COULD CAUSELOSS OF THE ABS FUNCTION, BUT NORMAL POWER ASSISTED BRAKING WOULD BE RETAINED.THE AMBER ANTI LOCK WARNING LIGHT WOULD ILLUMINATE AND STAY ON.
Corrective Action
THE ABS AND HYDRAULIC PUMP MOTOR ELECTRICAL RELAYS AND 30 AMP FUSES WILL BE REPLACED. IN ADDITION, THE HYDRAULIC PUMP MOTOR ASSEMBLY AND PRESSURE/WARNING SWITCH WILL BE INSPECTED AND, IF REQUIRED, REPLACED.
File Date 9/3/1987
Mfr. Involved
NHTSA Campaign #
87V135000
Mfr. Campaign #
Component Affected ELECTRICAL SYSTEM:FUSES AND CIRCUIT BREAKERS
# Vehicles Affected
479715
Defect AN IN LINE FUSIBLE LINK MAY MELT DOWN AND CAUSE A FIRE.
Consequence
THE IN LINE FUSIBLE LINK LOCATED IN THE AREA OF THEPLASTIC WINDSHIELD WASHER BOTTLE BRACKET MAY, UNDER A HIGH RESISTANCE LOAD,MELT DOWN AND IGNITE THE WASHER BOTTLE BRACKET RESULTING IN AN ENGINECOMPARTMENT FIRE.
Corrective Action
THE WINDSHIELD WASHER BOTTLE BRACKET WILL BE REPLACED.
File Date 5/18/1988
Mfr. Involved
NHTSA Campaign # 88V080000
Mfr. Campaign #
Component Affected VEHICLE SPEED CONTROL:ACCELERATOR PEDAL
# Vehicles Affected
35057
Defect
EXCESSIVE ACCELERATOR CABLE FRICTION MAY RESTRICT THE CABLES FREE MOVEMENT BETWEEN THE ACCELERATOR PEDAL AND THE THROTTLE BODY. Consequence THIS COULD PREVENT THROTTLE FROM RETURNING TO CLOSED(IDLE) POSITION WHEN ACCELERATOR PEDAL IS RELEASED; THUS, ENGINE SPEED WOULDNOT DECREASE, AND LOSS OF ACCELERATOR CONTROL COULD RESULT IN AN ACCIDENT. Corrective Action REPLACE ACCELERATOR CABLE.
File Date 5/22/2006
Mfr. Involved HONEYWELL INTERNATIONAL, INC.
NHTSA Campaign #
06E043000
Mfr. Campaign #
Component Affected FUEL SYSTEM, GASOLINE
# Vehicles Affected
88303
Defect
CERTAIN REPLACEMENT FUEL FILTERS, FRAM BRAND NAME P/N G3727, WITH DATE CODES X52911 THROUGH X60801 SEQUENTIALLY OR X600141 AND A MEXICO COUNTRY OR ORIGIN MARKING ON THE FUEL FILTER HOUSING MANUFACTURED FROM OCTOBER 18, 2005, THROUGH MARCH 21, 2006, SOLD FOR USE ON THE VEHICLES LISTED ABOVE AND ON CERTAIN SCHOOL BUSES. (TO SEE THE SCHOOL BUS ENGINE SIZES, CLICK ON "DOCUMENT SEARCH" AND THEN "BUS APPLICATIONS"). THE CONNECTOR ON THE FUEL FILTER WAS NOT MANUFACTURED TO HONEYWELL'S SPECIFICATION. AS A RESULT, THE O-RING MAY NOT SEAT CORRECTLY ON THE FUEL LINE.
Consequence THIS CONDITION MAY CAUSE AN INADEQUATE SEAL AT THE CONNECTION, POTENTIALLY LEADING TO A FUEL LEAK. IN THE PRESENCE OF AN IGNITION SOURCE, A FIRE COULD OCCUR.
Corrective Action HONEYWELL WILL NOTIFY OWNERS AND REPLACE THE FUEL FILTERS FREE OF CHARGE. THE RECALL BEGAN ON OCTOBER 18, 2006. OWNERS MAY CONTACT FRAM CUSTOMER SERVICE AT 1-800-890-2075 (OPTION 1).
*sorry if its a repost*
(\__/)
(='.'=) This is the original Bunny. Copy and paste bunny
(")_(") into your signature to help him gain world domination
*1987 Oldsmobile Ninety-Eight Regency Brougham.*
(deceased)
*2003 Ford Mustang GT*
just a CAI and Exhaust...for now
Old 12-18-2007, 08:39 AM
maxwedge maxwedge is offline
A990 racer
Re: Recall!!???
20 years later, anyway, check with you local Buick dealer to see if they are authorized to do this and if they have access to see if the Olds service records show if the recall was completed already. We used to put a sticker on the rad x brace to indicate it was done, I weas an Olds SM in those years. The last one is for a late model car, the other ones do not list the years.
Old 12-18-2007, 08:05 PM
Re: Recall!!???
yep i'm late on the recall info. I was just that bored last night I decided to post it. I had to pull an all nighter catering event.. that really sucked sometimes I hate freelance work.
(\__/)
(deceased)
