Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 12-17-2007, 10:01 PM
mrwrong mrwrong is offline
Red face Smoke from under hood-
My 93 caprice with single exhaust, has a lot of smoke coming out from where the exhaust manifold and pipe connect. When I looked at it, it had some oil on the connection. Where I should at trying to fix this? Thanks in advance
Old 12-17-2007, 10:08 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Smoke from under hood-
Valve cover gaskets. Make sure the valve covers are tight, but not too tight, although the centerbolt valve covers use an RTV seal.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 12-17-2007, 10:20 PM
PeteA216's Avatar
PeteA216 PeteA216 is offline
Send a message via AIM to PeteA216
I just realized Silicon posted a reply here, so I'm pasting my reply from the duplicate post so the other one can be removed.
It sounds like a possible valve cover gasket leak to me, but depending on which side it's on could also be coming from the oil filter and squirting on that area of the exhaust. It could be even coming from somewhere else, but it is obvious that you have an oil leak somewhere in that area, and when running the engine, the exhaust heats up and burns the oil off, explaining the smoke. If you're having trouble locating the leak, clean the engine with engine degreaser and a pressure washer such as at the self-service car wash, then run it and check for oil seepage anywhere.
Old 12-18-2007, 12:01 PM
mike561 mike561 is offline
Mine does this on and off as well, i know its the valve cover gaskets but just one of those things i havent gotten a chance to get to yet.
2006 Chevy Cobalt LS
Old 12-18-2007, 03:55 PM
Thanks for your input guys. Valve cover gaskets are brand new, but I may have installed them incorrectly. Do I set it in the valve cover groove, or on the engine block itself, then set the cover on top? It's the valve on the passenger side that is causing all these problems.
Old 12-18-2007, 06:00 PM
silicon212's Avatar
Confoundingly Lucid
The silicone gaskets are put on the cover and then the cover/gasket installed on the engine. Otherwise, you will never get the gasket lined up properly.
Old 12-18-2007, 06:43 PM
Aright, thanks a lot! I will try to fix it tomorrow if it stops raining.
Old 12-19-2007, 12:21 PM
bhw33191's Avatar
bhw33191 bhw33191 is offline
Send a message via AIM to bhw33191
I had the same problem a few weeks ago and sure enough it was the valve cover gaskets. For me it was the one on the drivers side; i recommend replacing both unless you know they are in good condition, otherwise make sure the covers are tight because i know mine wasnt when i took them off. Most likely what happened when you replaced it was the gaskets were not glued good enough or didnt dry when you put the cover on, therefore the gasket got out of place when you were moving it through the maze of cables and wires onto the engine.
'83 Caprice Classic LM1 (truck) 350 swap. about 200HP, 305 ft/lbs..for now.
-- 65,000 original miles --
