Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 12-17-2007, 06:05 PM
Ricardo_france's Avatar
Ricardo_france Ricardo_france is offline
Heat valve control line
Hello.
I've some questions about the heat system on my '77 caprice.
The A/C works fine, but no heating (since I bought the car)
I've located the heater valve, but the vacuum connector is blocked by a screw. (1)
On the right side (near the blower box), I found 2 small vacuum lines (1 white and 1 brown).
How do I plug these 2 lines ?
Another question:
What's this part ?
Thank's for your help
1977 Chevrolet caprice Sheriff
1993 Buick Park Avenue
1995 Kawasaki KZ1000P (P14) CHP
1977 Renault Estafette
Old 12-17-2007, 10:08 PM
PeteA216's Avatar
PeteA216 PeteA216 is offline
Send a message via AIM to PeteA216
Re: Heat valve control line
These disconnected vacuum hoses are definately the cause of no heat. The black sphere is a vacuum globe, which acts as a vacuum "buffer" to help keep vacuum in the system even at WOT. This particular vacuum globe buffers the vacuum for your vent controls, switching from floor, to the main front vents, to the dash defrost vent. It's also likely it supplies the heater line valve with vacuum as well.
Old 12-17-2007, 10:22 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
The 'orb of nothing' as Blue Bowtie calls it (because it's a vacuum sump) connects between intake manifold vacuum (connects to a port on the intake behind the carb, a TH350 vacuum modulator line connects to the same fitting - this is called MANIFOLD vacuum as opposed to PORTED vacuum), and the underdash vacuum system that operates the various doors and controls on the A/C system.
The heater control valve is supplied with vacuum that is sourced from under the dash - it's usually a brown colored 'hard line' (plastic instead of a rubber hose). The white line supplies vacuum from the vacuum sump to the underdash network. You don't want to plug either of these if you want your heater to work as designed.
Part #1 is your heater bypass valve (as you stated),
Part #2 is your EGR valve, and
Part #3 is your EFE heat riser valve diaphragm.
Part #2 receives vacuum from a PORTED source through a ported thermal vacuum switch (TVS) on the pre-computer cars, and part #3 receives ported vacuum through a separate TVS.
On the computer cars, an electric relay replaces the TVS for the EGR.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 12-18-2007, 08:03 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
Not that you asked, but.. you didn't have to strip it to the bare block to get to your heater control parts.
Bob
Old 12-20-2007, 01:14 PM
j cAT j cAT is offline
that engine needs rebuild. i think your heat problems are now the least of your concerns...
Old 12-20-2007, 03:36 PM
Thank's to all.
Some precisions:
My engine worked well, but some hydraulic lifters were noisy.
That why I opened my engine.
beuarkkkkk !!!!
The EFE valve ... blocked closed
Now, the engine is rebuild.
EFE and EGR were removed.
