Go Back   Automotive Forums Car Chat > Ford > Mustang > Performance
Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here.
Old 12-17-2007, 04:52 PM
onebadazzsrt onebadazzsrt is offline
need help with swap
I've got a 90 fox body with a bad motor, I've read on the net you can drop in the 03 svt motor. does anybody have any info on where to look, I am very good at swapping motors and such but just need to know where to get the k-frame and wiring,
Old 12-17-2007, 05:33 PM
TENGRAM TENGRAM is offline
Re: need help with swap
i believe maximum motorsports has a k-member specifically for that swap. the wiring/ecm you would have to get from the donor vehicle.
its an interesting swap but in the long run it would be cheaper and more effective to build a 302 or 351 based engine.
1999 geo metro LSi
1989 ford mustang gt www.my5oh.com
Old 12-17-2007, 07:36 PM
so i'd be better off super charging a 5.0, if I were going to use a 351 wich is the better one the cleveland or windsor
Old 12-17-2007, 07:51 PM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
Windsor - same block design as your 5.0
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 12-17-2007, 07:52 PM
clevelands are great, BUT it will be much easier/cheaper to get the windsor in there. you would need a 351 swap oil pan and i believe some brackets for the accessories, all of which are available through FRPP and many other sources. its about as easy a swap as you can get and you can make 700+ HP without fear of the block coming apart.
a 5.0 stroked to 347 would be another great choice but, with the power levels that i think you have in mind, a better aftermarket block would be a necessity.
1999 geo metro LSi
Old 12-18-2007, 12:07 AM
351wStang's Avatar
351wStang 351wStang is offline
I swapped a '89 5.8l into my old '87 mustang coupe. I was making about 600rw with a Vortech S-trim @ 14psi.
You will need:
Headers
Oil pan
Brackets (I made my own)
Belt
Crank pulley spacer
Cowl hood or scoop
- I may be forgetting something, thats all I can remember of the top of my head.
Swapping a 4.6 into a fox requires lots of fab work. Most people chop up a distributor and run it off of one of the cams. There is a ton of other stuff that you have to change/modify. Its no easy job.
1969 Cougar
357w & TKO - 475hp
