Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 12-17-2007, 12:41 PM
boatman01 boatman01 is offline
Cool 99 suburban remote entry programing
I purchased a key fob off ebay that is supposed to work on my vehicle, but I am having some trouble programing it. Can you give me the exact procedure for programing it please.It is a 1999 suburban 2500. THANKS.
Old 12-17-2007, 04:46 PM
777stickman 777stickman is offline
Re: 99 suburban remote entry programing
Welcome to AF.
If your '99 is an "old body style" try this.
1. Jumper pins 4 & 8 in the DLC. Pins 1 thru 8 are the top row left to right.
2. The doors should lock and unlock.
3. Press and hold the LOCK & UNLOCK buttons at the same time until the doors lock and unlock (approx 10 secs).
4. If you have more than one FOB they must all be reprogrammed at the same time up to a max of four.
5. Remove the jumper and test each FOB.
This info is out of a '98 GM service manual. If your '99 is a "new body style" this may not work.
Hope this helps and good luck..........Steve
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 12-18-2007, 10:20 AM
Happy Meal's Avatar
Happy Meal Happy Meal is offline
Got one off ebay too. It came with directions.
1. Close all dorrs
2. Insert the key into ignition.
3 Hold down the power UNLOCK button on the drivers door panel CONTINUE TO HOLD DOWN UNTIL INSTRUCTED TO RELEASE.
4. Perform steps 5 through 8 in rapid succession.
5.Turn the ignition to the ON position (as far as possible without engaging starter)
6. Turn the ignition switch to the OFF position
7. Turn the ignition switch to the ON
8. Turn the ignition switch to the OFF position
9. RELEASE THE POWER UNLOCK BUTTON on the door panel. The vehicle will lock and unlock the doors automatically.
10. Hold down the LOCK and UNLOCK buttons on the transmitter simultaneously until the door locks and unlocks. This may take up to 30 seconds.
11. Repeat step 10 for each additional remote NOW.
12. Turn the ignition switch to ON in order to exit the transmitter programming mode.
OR
Go with 777stickman's directions (which worked for me).
