Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 12-17-2007, 11:17 AM
myrezi myrezi is offline
I think its my fuel filter
Guyz, so for a few days now, when driving, my car would just swtich off, After letting it sit for a few minutes it would start back up like nothign is wrong. My gas guage tendes to be incorrect a few times.
Im thinking its my guel pump or filter
Where is the fule filter located and is the fuel pump in the tank or outside
let me know
thaks guyz
Old 12-17-2007, 02:36 PM
jonnik jonnik is offline
Re: I think its my fuel filter
Year, engine, miles?
Old 12-17-2007, 05:42 PM
Its a 2000 v6 156k miles
Old 12-17-2007, 06:00 PM
RaeRae1's Avatar
RaeRae1 RaeRae1 is offline
Send a message via AIM to RaeRae1
Ok - what kind of car???? if you want help, you have to give us more information than that. What engine, specifically? Are you going to actually give us the make of your vehicle? Sorry, but it is pretty close to impossible to help without more information.
Blessed are the cracked ones, for they are the ones that let in the light.
Originally Posted by 72chevelleOhio
Your cheer-mobile needs a flat tire.
Old 12-17-2007, 09:33 PM
stratford_boy stratford_boy is offline
Well, if he's here, that more than likely means its a 2000 mali with the 3.1 v6! Never seen a fuel filter do that before, bad fuel pumps usually don't cause random stalls, usually just a no start. In terms of the innaccurate sending unit, does your car have the steel or plastic tank?? The plastic tanks were bad for innaccurate sending units, and GM actually had a conditioner that you had to run through the tank to try and clean the sending unit brushes...never seemed to work. They do sell the sending units separate from the pump, but if you have the tank out, why not do them both??
Do need a little more info...hot or cold stall?? Under load or idling at a light?? Accel or decel?? No such thing as too much info!!
Old 12-18-2007, 07:08 AM
Speedy_1234 Speedy_1234 is offline
Send a message via AIM to Speedy_1234 Send a message via Yahoo to Speedy_1234
Is the check engine light on? Is the Service Engine Soon light on?
If So any codes? Have you ever change the fuel filter before? Have you done a tune up. Hows the battery is it good? Is the alterantor charging like it suppose too?
opcorn:
Old 12-24-2007, 09:36 AM
So its a 2000 Malibu V6. The stalls accure when driving, the car will be warm, then would just cut off. If you give it a couple of minutes it might start up.
NOW
I have the plastic tank. I got a new fuel pump and going to put that on.
just dropped the tank last night.
So hopefully it will work.
With old fuel pump, car would not start, it will turn over but would not start.
So hopefully it is the fuel pump.
I also bought some aditives to run through it Like fuel injector cleaner and fuel system cleaner.
wish me luck
dont want to be in the new year with out a car
and thanks for all the replies
Old 12-24-2007, 09:38 AM
NOW
wish me luck
Old 12-26-2007, 03:01 AM
16th hippy 16th hippy is offline
had one that did close to same things, turned out only in summer and when was kinda warm out. fuel pump relay was overheating and cutting out. replaced relay and was good togo.
Disclaimer: I am not perfect, i may be wrong in my advice from time to time. Also note that any advice given is as is with no warranty whatsoever, and i have zero liability if you get hurt for not being safe while working on your vehicle.
